Space Duster
Watching this one.
The exhaust pipe on the right side of the pic there is bolted to the header and I did have the drivers side bolted up as well, all clears with plenty of room.One area of concern I have is your cross member clearance for your exhaust. This was an oversight when I built my car and didn't know if you had a plan yet cause it's really going to hang low......
Sounds good...just making sure you thought it all out...I really think I would spray a matte clear over the body and call it a day, I like the patina.The exhaust pipe on the right side of the pic there is bolted to the header and I did have the drivers side bolted up as well, all clears with plenty of room.
Eventually tho I think I'm gonna run TTI shorties, oval tubing exhaust and either an AAR-T/A style dynomax muffler or a spin tech muffler and side exhaust, all tucked up tight so I can slam the car and the exhaust/headers won't be the first thing to hit
I also did a wiring mod that slantsixdan recommended, ran 2 10 gauge wires with 50 amp fuses at each end from the alternator to the + post on the starter relay. Don't worry, the yellow yip ties are temporary.
You can run a bigger alternator and it bypasses all the smaller factory wiring. Also goes straight to the battery instead of going through the bulkhead connector, ammeter and other splices/connections under the dash.I'm not familiar with the advantage of doing this Modification.
