Spun Bearing
Lost in Space
x2 - Shouldn't affect the rear ride height at all.My rear ride height shouldn't be effected.
Whatever you do in the front shouldn't affect the height of the rear at all.The HDK is a pretty basic install untill you get to the front and rear ride height I want to see how yours will set and what you used to get there
What do you mean? I Ordered 10" coil overs and 500lb springs. My rear ride height shouldn't be effected.
From what I read, in the front you install the shock simulators and with the wheels/tires you want to run, you set the simulators to one of their three presets which emulate the three most popular shock body lengths. This is the length of shocks you order. Simple.
The spring is then chosen by what lb. rate spring gives you the recommended amount of sag when laden.
That's it. The rear end is not involved whatsoever.
nice job.....I noticed you swapped out the upper polys for heims.......I am thinking about that as an option
I was reading where on the top cars at the Musclecar Drags.....You know, the ones that are picking up the front wheels while running skinny stock-looking bias plies out back? That they have rollerized every single suspension pivot point. That's as in replacing every single suspension bushing with needle bearings to get the car to move and transfer all of the weight effortlessly without having to overcome the friction and resistance of the bushings. Rock on back!they do move more freely. I just mocked it up on the one side to see how i liked it. this is a street strip car so I think it might help with weight transfer. I could be wrong though.
All 4 corners
Nice rims.Are they 4'x5 ? Where,d ya get them?
