My HDK install thread.
Nope! Rears are 345/45/17
28" tall 12.5" wide on 17x11 rims
Holy cow batman now youv'e really got me wondering about your front to rear stance can't wait to see the end result that's pretty much the OD front - rear tires on my Valiant and without doing something major to the rear I couldn't get it low enough to get the car somewhat level - your not using a 4 link are you - of course my car is a short square box and not as much wheel opening as you have
this is with the old front end. it does sit pretty low.
Now we just got to hit the autocross course and see how much time that sucker takes of the slip! I'll play the baseline, You play lead guitar!
How did you get the rear to set so low I have ESPO stock ride height leafs and fliped the front hanger
I am running the caltrac mono leafs in the -1" set up. I also have sliders on the rear spring eyes notched into the frame.
and my springs are as far up into the frame box as possible and i installed the boxes way up into the frame.
OK,
I've read the whole post and the car looks great! Going back to the first set of pics - now tell us about the very cool looking tri-bike in the back of the photo (first page of the post). That looks awesome.
Car looks great dude!
Joe
OK,
Joe
That's my trike that I built for myself and my buddies. It's got a harbor freight Honda clone engine that I completely rebuilt. Cam, piston,rod carb etc, turns well over 8k rpm and does 55+. Total blast to ride. Built it all from scratch
I just finished installing my HDK in the Hemi Barracuda and all thats left to do is the steering shaft. If you think your install was easy you should have seen mine. Easy as pie.
Did I mention Old_man_mopar and HemiDenny came to Pittsburgh for lunch and a HDK install!
This front suspension is so well built and I couldn't be happier. Thanks again Denny. :thumblef: FYI, your ride looks super!!!
I know a Big Wheel when I see one.......and that's one!:cheers:
Got her back on her feet tonight. This is no engine or trans. Front ride height will be 1-1/4" lower.
Got her pushed out of shop this morning. This is no motor or trans. Front will be adjusted one inch lower.
