MY Molded Mopar Model parts!?
67 Power Wagon
Hemi Pawr or BUST!
Hell, USA
Quick update,
Mopar 383
Mopar 400
Mopar 413
Mopar 426
Mopar 440
See:
The following is a SPECIAL Set, notice that "Valves" in the combustion chambers!
These ----^ Engines are ALL Mopar Big Block "Wedge" engines.
Hemi's are to follow!
THEN I have:
Mopar 426 Hemi
Mopar 472 Hemi
Mopar 528 Hemi
Mopar 540 Hemi
AGAIN those above are a SPECIAL SET.....
Nice Jo-Han replacement set, SINGLE plug per cylinder model! Dual Plug version in the works!
AND AGAIN the above Hemi Valve Covers, are a SPECIAL SET, they are molded from the NICELY done Jo-Hans of the 70's, (I must have had the factory originals for 25 years!)
These all are the same as well, in real life ONLY the bore of the engine cylinders were different outward appearance was exactly the same on ALL of them!
NEXT up, the 426 Dual Over Head Cam Hemi parts!
THEN I have:
426 DOHC Hemi:
SAME Block for ALL the Mopar Big Blocks!
Special set of Heads for the DOHC Hemi ---^
Detailed underside huh? ^----SHOWN "Valves" in the combustion chambers!
Then, a few "extra" Hemi parts.... (I WILL have a LOT of these to come....A recent "trade" wiped me out and this was the only one left!
And last, but not least.....
Exhaust Manifolds! Seen here ONLY, they're not "cleaned" from "Demolding" them from the molds ALL my parts go out CLEANED, ready for use on any model! These will fit to ANY of these engines so far, BUT are actually to the Hemi's ONLY in real life! 440 Wedge engines had a version of their own just as these were really the Hemi's "own".....
Mopar Small blocks are coming next!
Yes gentlemen, I WILL be selling this stuff! The cool part is, I'm NOT like other Molders, I'm ONLY doing MOPAR!!!!! PM with interests....
ALSO, I will consider trades, specially if I can use things for masters I don't already have!
MORE to come! :D
Then to the Mopar small blocks or "LA" engines I have:
Mopar 318
Mopar 340
Mopar 360
Special set, of the Mopar 273 V-8 ---^
These can be used for ANYTHING from the Mopar 318, to the 340 to the 360....
Can't forget the Transmission Torque Converter pan can we?
Mopar Slant 6's are NEXT!
I have 2 different versions of the following:
Mopar 226 Slant-6 cylinder engine, one with the transmission, and a second one, that the engine and trans are separate, for those detail enthusiasts out there.....I'm also awaiting the molding process, to cure to have a "stock" type valve cover to the Slant 6's and a "custom" version of it.....This "look" will choose the block as they are slightly different in length due to the fact the way the masters were made, the engines are not from the same manufacturer of the parts.....BUT I *think* with a little work the valve covers could be made interchangeable from one casting to the other.....
Mopar "Factory" valve cover ---^
BOTH of them above!
A FEW Mopar Slant 6 custom parts NEXT!
So then, this "next" group, are a combination set of parts, NOT only can this engine be a Slant 6, with the current "head" cast on it, BUT also serves as the Aussie version known as the Hemi-6, which was 245 Cubic Inch AND the 265 Cubic Inch 6 cylinders....
The above 2 pictures are of a CUSTOM Mopar Slant 6 valve cover, NOT to be used with the following engine....
This engine ---^
Is the Hemi-6 from Australia! Thanks for the help Dale! AKA Deecee, I couldn't have made this possible without your help! Thanks man! (Even tho, I have more to go on it), a 1/25th scale model will be coming of this USA "Phantom"....
Transmissions are up next!
Mopar Transmissions:
For the Slant 6....Notice starter location!
Carburetors are done too, as well as power steering pumps, starters, and a few "small" details...I plan to do oil filters and I'm not sure what else as far as small details, we'll see, ANYTHING large, and has to do with Mopar, I take that as a "yes". it WILL be molded!
Anyone see anything you like? Send me a PM on it......
Also so EVERYONE knows, as you see them here.. "clean" is how they will come to you if ordered, or traded for............. There is VERY little cleaning work to get them to be usable with my castings, you WILL have to paint the part, and assembly is with some sort of super glue, BUT that is it! They're cleaned by me, to a modelers quality standing, so that not only I can use them, BUT ANYONE!
The only catch to using these parts as I have said, is they need painted, and assembly HAS TO BE with super glue, slow acting, or instant, super glue will work! Fix-All adhesive from "Super Glue" the company, will ALSO work! I've tried them all!
Any interest, PM me!
How about air cleaners? I have some cool ones, including many nice air grabber ones from Johan.....I would let you use them for molds if you want, I have a lot of other cool Mopar model parts that are hard to find, let me know!
BTW, this stuff you are making is awesome!! Nice job and keep up the cool stuff :glasses7:
Thanks Keith! YES Air cleaners, for god sake man PM with what ya might have! I don't have many to do right now and I'm trying to collect as much as I can for mold making.....
You a modeler too? HELL I'll trade ya parts for parts for the factory stuff for anything you see here, I DO have but one air cleaner made, its a Edelbrock model.....BUT haven't gotten a pic of it yet.....
I used be real big into models but haven't done any in years....hope to get back into it again, I have a big collection of mopars, many are older ones and all unbuilt. I have lots of air cleaners, I'll look through my stash and see what else I have too you might be able to use.
Took lots of pictures, I'll post them up a little later on when I have some more time
Here are some of the air cleaners :glasses7:
MPC/AMT 426 Hemi Crossram 66-67?
Here is a rare one, 65 426 413 street wedge....would also work for the 67-68 BB A-Body cars
Here is my favorite, this one is unused and from Johan, 69-71 426 Hemi, its a 2-piece lid and has the best detail and looks correct.....also work on a sixpack
