Great input. Finally some progress. Pulled the clutch/fan assembly and fired it up. Noise was noticeably less. Pulled the fan pulley and took a file to both sides of the v groove. Also same to the PS pump pulley in the car. In hindsight I should have done one at a time. Fired it up and quieter yet and possibly at higher rpm. Snugged the belt down tight and the screech now comes in about 3000 RPM and definitely not nearly as loud. Before it would make me cringe. Tolerable now. Looks like it may be from the Fan pulley. I'm headed to The Carlisle Chrysler Nationals this weekend and will be looking for pulleys. If not I can probably scuff these up better. Someone on Mike69cuda's thread above mentioned sand blasting the pulleys. Thanks for all of your help!!!!!!
Good experiment! So if you removed the fan, and it still squealed, I would take that to mean that the fan load is not the culprit, or at least not all of the problem.
Interesting that it squealed less, I wonder if that was because of the load water pump and fan together were causing the belt squeal and reducing the load lowered the squeal?
Or does it mean that the the problem is not the fan pulley and just a difference belt tension reduced the squealing? My brain hurts.....
