superstockcuda
Member
i am currently building another 68 barracuda fb, it is currently on a rotisserie striped top and bottom waiting to get soda blasted. im going to minitub it, frame connectors, and a mild cage for the street. i want to run the rms AlterKtion up front and run caltracs out back with a 8.3/4 rear. disc breaks all around. i want to run a 6.1 hemi, i want to run fast or the big stuff 3. i defiantly want to run a 5 or 6 speed because i want to run big gears in the back. i want to run a hydraulic clutch. i did a lot of research and i having trouble finding the right parts. what kind of transmissions are you running? i have a auto, but i want to do a manual swap so what company conversion are you using? what kind of hydraulic clutch set ups are you using? and all misc parts am i missing. i just want to know what you guys are running in your cars. thanks
