340_833 dart
To preface, last winter I rewired the underhood harness on my 73 Dart Sport 340. Instead of going with the factory style harness and spade connectors, I bought several different colored rolls of wire and used weather pack connectors.
I also used a weather pack bulkhead connector.
Because I am running an Accel 300+ ignition system, I was able to do away with the factory control box, the ballast resistor and all the related wiring. I did my best to replace one wire at a time so as to make sure the essential wires remained.
Well, when I tried to start the car, it cranked just fine but would not fire. I eventually tracked the problem to not getting power to the Accel ignition box. I tried finding the wire out of the ignition switch that gets power with the key in the start and run positions but was unsuccessful. In order to get the car to run, I had to wire an on/off switch to the ignition box.
Now, when I want to start the engine, I have to flip the switch on, then crank it. But, I cannot kill the engine with the ignition switch. I have to flip the auxiliary switch off.
So, long story short, I need to know what color wire on the stock ignition wire harness is the one that needs to run to the Accel box. Where does that wire get its power?
I plan on selling the car in a couple of months and want to again be able to start and stop the engine with only the ignition switch.
I've got a wiring diagram but, it might as well be written in Chinese. I've studied it a long time and still can't figure out which wire I need and how it's routed.
Thanks.
Thanks.
