How about replacing the fuel filter? He may have prime and pump shot but bowl is empty. He smells no fuel.
could be the fuel pump escentric came loose and is flopping around and not positioned on the key way and not supplying any fuel to carb. another try > having someone crank the engine over with key and spray carb cleaner into carb when cranking it over. see if it pops.How about replacing the fuel filter? He may have prime and pump shot but bowl is empty. He smells no fuel.
A real 60 lbs of compression, kinda running out of options. The OP might not recognize the difference in how it would sound. Huffing back out the carb and the spark might be weak enough not to create pyrotechnics.I was thinking the valve thing too! But what are the odds.
make sure the pushrods are not bent. 60# compression. valve train issues... lets see some videos of what's going on with it . pictures are worth a thousand wordsHe has tried alternate fuel source, separate from the carb/fuel system. What is curious is it does NOTHING, but turn over? No pop, no snort, no kick back, no unusual sounds what so ever when turning over, but it has fuel out of the accelerator pump and “spark” at number 1. My last guess, assuming the 60 lbs is moderately accurate. It jumped time, bent every valve (in the subsequent starting efforts) or pushrod and the 60 lbs is real. A video of it turning over would be invaluable.
If you're jumping in with an idea, at least read post #156. Kuz took the time to do a thorough recap of what had been tried up to that point.He’s verified rotor is pointing at #1 terminal when engine is at tdc, he’s sprayed starting fluid down the carburetor, and he took the compression test with an oldercompression tester that pushed against the spark plug hole, not screwed in. The last sentence makes me question how accurate 60 pounds is so don’t get too hung up on that number. He’s also ordered a screw in compression tester and is awaiting delivery. Even though it’s a very long read, it may be worth it to those who post ideas to go back and look at everything that’s been done over these last eight pages. Chances are it’s already been suggested and done. I ran out of ideas a long time ago and suggested that he get another set of eyes to take a look at the car.
It's not firing at all, has spark, already used squirts of starting fluid...I know You don't feel like reading all 9 pages, but ......How about replacing the fuel filter? He may have prime and pump shot but bowl is empty. He smells no fuel.
Only problem with the water theory is that fuel floats on top of water. At the moment enough water is introduced the only fuel in the system to run the engine would be what ever is in the carb bowl and the fuel lines from the tank to the carb. how many miles could one drive using only that amount of fuel? startup to maybe a mile. Yes there is jostling in the tank so the engine could in theory get enough gas with the water to keep running at speed. If the water was very little it might not reach the pickup at all times (angle of the car, acceleration, deceleration, sloshing)I buy my gas from the same 7-11 store for my Barracuda and d-150 Dodge pick-up . I have no choice but to drive the truck now and it runs fine . I did get water in the tank of my truck many years ago . Every time I pulled up my steep driveway , water in the float bowl moved into the engine & the motor nearly cut off before getting up the hill . I had trouble getting the tank empty , so I ended up removing the tank to get the water out .
Actually I did read all the pages. The recap shows no fuel filter change. Cheap enough to try.It's not firing at all, has spark, already used squirts of starting fluid...I know You don't feel like reading all 9 pages, but ......
Went to the Dentist this morning in the pouring down rain . Plan was to stop & get a gas filter , distributor cap and rotor on the way home . Just my luck the wiper linkage bushing broke or fell off . Anyway , I could not hardly see to drive , so I took the shortest route home without having a wreck . Still raining , but sunny tomorrow . I will go out tomorrow and get those parts , including the wiper bushings . Done that on the barracuda years ago . Probably hard bushings on the barracuda by now . Might as well fix that problem before it happens .Actually I did read all the pages. The recap shows no fuel filter change. Cheap enough to try.
I wonder if you might could get us a video to highlight two things. First, to let us HEAR the engine turning over. If it has jumped timing, it will be distinctively different sounding from an engine that's in time. Secondly, set up your spark testing outfit and spin the engine showing the spark. That way we'll have two good things where we can offer opinions on from solid evidence. Glad you made it back home. Do you have some RainX? It's good stuff. Get some if you don't.Went to the Dentist this morning in the pouring down rain . Plan was to stop & get a gas filter , distributor cap and rotor on the way home . Just my luck the wiper linkage bushing broke or fell off . Anyway , I could not hardly see to drive , so I took the shortest route home without having a wreck . Still raining , but sunny tomorrow . I will go out tomorrow and get those parts , including the wiper bushings . Done that on the barracuda years ago . Probably hard bushings on the barracuda by now . Might as well fix that problem before it happens .
I presently have a clear amber colored inline gas filter . I see it nearly full with a slight bubble at the top . The new fuel pump keeps it full . I get gas every time I move the throttle back .
A real oil pressure gauge , with direct copper line to the engine . Neighbors are white collar types with modern cars . Not mechanical minded from what I know of them .Do you have any questionable neighbors? Serious question. Also. What is the aftermarket gauge below the key?
Pump gas peddle twice & hold down to the floor & then turn the key to the right for about 30 seconds . I have not removed the valve covers , yet . Let me get the other suggestions above , done & see where it stands . I will have to order gaskets before I remove the covers .can you please describe the procedure step by step how to attempt the crank the engine over with key.. ? are you pumping the gas peddle , holding it to the floor while cranking and how long cranking .
are you checking to see if push rods are not bent or broken rocker gear?
