Using sewing machine weight oil will do it every time.
I guess it would be really easy to make comp cam not lose it's **** if you ran some super weak springs and put the real springs in after it's a known survivorA guy down the road has never had a Comp cam go flat, must be luck I guess.
Maybe that's why he retired to keep the luck going. lol
Yeah but who's to say upon replacing the weaker springs with the right ones it won't wipe lobes? In fact, nowadays with any brand flat tappet, who's to say it won't happen? What I am seeing is there are way less failures with solids than hydraulics, but that's just me. I don't know about everybody else.I guess it would be really easy to make comp cam not lose it's **** if you ran some super weak springs and put the real springs in after it's a known survivor
You mean Jim Laroy? Yes, he did. He also knows the right people to talk to at Comp. .....or did. I think he's about retired now.I think Jim spec'd his own cams
Yeah true, but in theory it should be work hardened by the time a normal break in happens.Yeah but who's to say upon replacing the weaker springs with the right ones it won't wipe lobes? In fact, nowadays with any brand flat tappet, who's to say it won't happen? What I am seeing is there are way less failures with solids than hydraulics, but that's just me. I don't know about everybody else.
I put Crower Cam Savers in this Ford 400 I built for Gladys and while they broke in fin and had a great wear pattern, their valving was defective and they all ticked when the engine got hot. About 175 bucks down the toilet. I got some Melling $4.99 each lifters from Summit and zero noise cold or hot. Go figure.Yeah true, but in theory it should be work hardened by the time a normal break in happens.
I run solid flat with edm lifters + 20-30 lbs more spring pressure. But I sure am not running a comp,
If I count the 602 crate motors we see more failures with solid flat tappets as a percentage.Yeah but who's to say upon replacing the weaker springs with the right ones it won't wipe lobes? In fact, nowadays with any brand flat tappet, who's to say it won't happen? What I am seeing is there are way less failures with solids than hydraulics, but that's just me. I don't know about everybody else.
Yep it's weird how **** ends up happening.I put Crower Cam Savers in this Ford 400 I built for Gladys and while they broke in fin and had a great wear pattern, their valving was defective and they all ticked when the engine got hot. About 175 bucks down the toilet. I got some Melling $4.99 each lifters from Summit and zero noise cold or hot. Go figure.
I've had other people say Mellings worked well, too. When you look, you see they are made in two places. USA and Mexico. If that means a thing.Yep it's weird how **** ends up happening.
I work mostly on cylinder heads and see a lot of BS hydraulic lifters coming in rock solid causing bent valves. But that's mostly **** wearing out or people not changing their oil when they're supposed to.
I just bought a new set of old stock Johnson lifters off of FBBO. Considering sending 2 cams out to Oregon Cam Grinding to have them both reground. I have 2 sets of old lifters that I'll have resurfaced tooSo if you have to really dig in to remove the rust, you're also taking out base material. Just food for thought. Even something heavily rusted can shine up with enough sanding.
That said, your biggest source of flat tappet failures these days is lifter faces not properly ground. There's a guy in YouTube, Powell machine inc, he does a good job explaining what's going on. Worth considering sending your lifters out for a cleanup pass especially if they're newer.
Does Oregon resurface lifters?I just bought a new set of old stock Johnson lifters off of FBBO. Considering sending 2 cams out to Oregon Cam Grinding to have them both reground. I have 2 sets of old lifters that I'll have resurfaced too
