B3422w5
so the holes could actually be quite a bit smaller?
Yes, the width probably couldn't change much but the length could. As you can see I missed some on the passenger's side, the bend starts sooner than I thought it would. I wanted to make sure there was enough room for the engine to move.
Have you looked at these guys?, page 12-13Anybody have a picture of how big the hole is for the Headman 75140 in an A body. Think just a single tube goes outside on these?
Catalog — Tubular Automotive
Very nice race header and no hole but you do have to use adapter plates (they have those as well)which makes it nice for getting at the header bolts. I was going to go with the hedmans but was a little worried about how far the tube hangs into the wheel well since I run a fairly tall tire. I got lucky and ratbastid found me some hooker 5303s and I will say they made a significant difference over the dougs, not even the same car really, took a totally different tune up. I wasn't sure how much gain there would be since I don't have much cam etc. but he made a believer out of me lol!.
That's WAY to much for a set of headers, I don't care how good they look. They won't perform any better than a $700 set of headers which by the way is pretty much the price for good headers for a mopar
North and South could tighten up..East and West about how you have it?
I cut 3” round holes for the 1-7/8 heddman race headers for W2sYes, the tubes are 1 7/8" and I think I used a 2 1/4" hole saw, maybe a 2 1/2". I'd have to check, it's been several years.
That's the problem around here, people can disagree without comment.you didn't answer the question. you disagreed with my post saying no power steering and they look to hang low like any of the cheap junk headers. you pretty much reinforced what i typed and you disagreed with.
I think I remember a thread that mentioned that now?, lately I can't remember what day it is!.I almost bought a used set just a little while back from a guy on Moparts .They appear to hang too low to get on and off my trailer, but I might be wrong. Saw a picture of them from underneath behind a car looked like the collectors pointed down. I do like them
Off the wagon.....This **** is why I stopped posting here.
and again. you just agreed with what i said. but you disagreed with it. lol. jackass.
do they or do they not fit with power steering??
are they designed to go under everything like the cheap headers on the market? yes/no ?
This is Hooker Super Comps and there is no skip tube and I have power steering.Uh, on an A-body the super comps DO go below the steering link, and have a removable slip tube. On B/E bodies they stay above the steering link.
Ok ladies and gentlemen My 72 duster is the car they designed the headers around. There built for 318 340 or 360 with STOCK cylinder heads and No power steering.. the car has a stock 4spd with a scatter shield so there is plenty of room for automatics. My 340 has 11.1 comp. fully ported j heads big hydrolic flat tappet cam strip dominator and a reworked 750 Holley. I had old 1 7/8 hooker race headers on it for A and E bodies that they discontinued along time ago. I will say this, these headers blow away all those other headers and I had them all! You can install and remove them with the engine in the car! That alone is worth it to me. They changed the whole tone of the engine the car has a lot more low end torque and it pulls harder going through the gears the merge collectors actually work I will post some pics within a few weeks when I have time off underneath the car from both sides.
I am changing the motor and may give up power over use being practical . So thinking I need ground clearance and may go Doug's and go smaller tube. As my wife will kill the Hookers.
Only want to run pipes once not once for Hookers and then Change them for Doug's
Let's just back off and take a deep breath here.
I have had those Super Comps 25 plus years. Ther are Super Comps with large tube and are not Comp.Just for the record, the “super comp” Hooker headers were STREET headers. Period. That’s what you have.
The competition headers were called that. Competition. If you want I can post picture of the catalog that shows that.
Seems everyone thinks the super comp headers were something other than a street header. That’s all they are, and some of the part numbers are just junk.
LOL... that's rich...Naw, I’m going back to just looking. It isn’t worth it to argue with ******* idiots all the time.
Hooker made two different sized super comp headers, 5204 with 1 3/4 tubes and 5303 which was the "race header" with 1 7/8 tubes. The 5204 is a fully welded together header, where as the 5303 has slip fit collectors/tubes and once you cut the flanges can be installed in three pieces in the car.I have had those Super Comps 25 plus years. Ther are Super Comps with large tube and are not Comp.
You must be loads of fun at parties.
They are what they are. I was not even directly talking to you since you are rude and set in your ways. I was posting to state there is no Slip Tube.
As it was not correct to say they have a slip tube. Carry on.
Not sure if the "poke" emoji is appropriate but until they have a "madman screaming at the traffic" emoji, then I guess that's gonna have to do..Yay, Rat Bastid's back!!
