j par
Well-hung Member
These are the instructions for the low pressure switch..
First I wanted a bypass switch on it to check other systems...
Second after the power on/off switch I want to loop in the button on the shifter.
And third I wanted to put the timing retard signal wire in after the switch... That way I can have an assistant hit the switch while I adjust and check timing...
Also I was going to have the fuel pump on its own power switch.
Also the Purge on its own button and standalone power..
