I have had these run me all over the place chasing gremlins.
OK look, this here is a two way street. Please do as I asked you and post back the results. You are not looking just to see if there is power here and there ---you are looking for specific measurements. Re-read my post. Here is what you are after.Update..
I cleaned ecu plug connection.
With key on there is power to the positive side of coil.
When cranking there is power to negative side of coil...
When I mean power ..checked using test light
How do you know that is the problem. No you don't just tweak them. Do you know how to set breaker points? The reluctor gap is set the same way. If you look down in there is a screw to clamp one end of the assembly, with a sort of slot. You slightly loosen the screw, preferably using two screwdrivers, one in the adjust slot and one on the screw. Move it just a bit, re-snug the screw and see where the adjustment is.The problem is the magnetic pickup up is out of adjustment ...do people just tweak them with a pliers?
Did you measure it? What is the clearance? What is the shaft play?Look at picture...the screw and slot are all the way one way..no more adjustments !
What about the ECU; does it have 12V power with the key in both Start and Run? Measure with a multimeter instead of a test light.Update..
RE-read post 37. If the voltage to ground from coil pos and coil neg are the same, the COIL IS NOT DRAWING CURRENTUpdate:
With key on there is 12.4v on bith the negative and positive side of the coil.
When cranking they both drop down to approximately 10.5v
