jeffnmo
Just another Mopar Maniac
I'm not sure how much he drove it, It was parked at the tire store for a couple of months and then I seen it parked in a driveway. I never saw it driving on the road.
Jeff
Jeff
J Par (Jason) on here did his own 904 for the first auto trans he ever did and took it to the racetrack afterwards making some decent times.
Jeff
Torque flites are tough, hoping for the best!
Jeff
I'm about 55 miles away, I used to always go to the yearly Mopar meet but the last ten or so years my back has got so bad I can't walk to far, I might have to get me an old man scooter! Buy the way I'm glad that someone (you) got that car and is willing to put the work into it. Thanks.
Jeff
Hate to hear about your wife, I know how she feels, Tell her I hope she gets better soon. The next time I go buy the tire shop I'll pull in and see if the fella knows anything about the Dart. I've talked to him about front end alignment specs and he liked my car, He laughed when I said he couldn't drive it after the alignment to check it out but could ride along!
Jeff
Wow
That's impressive. Will the 904 bolt up with mine or would I need to do some adjusting? If I were so inclined to try that?
Jeff
Yeah the 360 main bearings were a weak point. plus i'm not a big fan of the long stroke crankshaft."Ok, so when I got the car, I got nothing to go on, literally guy lied and said it was a 360, it's actually a 340"
I love 727s, yes very easy to rebuild. just watch the tolerances.I say lucky you, 340 is much better than a 360. Did you check the side of the block to verify?
Torqueflites are one of the easiest transmissions to rebuild. There are many books out there on rebuilding them. My opinion is that transmission probably has some damage since it was run low on fluid (for how long??) and the lack of KD linkage. Unfortunately it will require more than just dropping the pan to know the extent of the damage.
I've got a couple of pics from the back of the car moving forward, not sure if this will help identify it.I think Dave has a 904 not a 727. The pick where he shows fluid and debris @ bottom of pan looks like a 904 pan. Just clearing things up.
I installed my lokar cable lastnight on my dart. Do yourself a favor and remove the 4 crossmember bolts and lower the transmission down. It'll give you so much more room.
Bigger bars for sure would not hurt, I'm running 1.03 bars from PST with Bilstein shocks, all can say is if you do this you will be very HAPPY! The bars are under engineered.
Jeff
No worries about why they should be replaced, just thinking that if I'm going to do this, I'd rather only do it once, so if I have to break them out, might as well replace them when they're outPST is a sponsor here on FABO, shocks and t-bars, Members get a 10% discount I believe. Maybe under engineered was the wrong word, they are not up to the newer tires, radial not bias ply.
Jeff
How much can it come down still attached to the motor? Do I need to lift the motor at the same time?
Jeff
a lot depends on intended purpose
if he is building a corner carver, im with you
but if his build a 1/4 drag racer, i would leave the slanty bars in
I pulled my distributor so it wouldn't hit the firewall. But I don't think it was necessary. I have rubber motor mounts and they flex enough that I didn't mess with loosening them.
Just support the trans with a jack, remove the 4 crossmember bolts and the one trans mount nut. Remove the crossmember completely. And slowly lower the jack down a few inches. I left the jack under it just to support it while I worked on it.
