Woods74
Broke Senior
Everything accept the fact it's still brass and not a babbit bushing...
If only someone had told me before I bought the kind that will ruin my tranny.
You can get a babbit bushing at o'reilly's.. Pioneer Part # 755100...
Didn't hear back, so decided the way I had it will have to do. Staked, packed, ready for bolts. Look copacetic?
Just finished reading through this, and boy do I wish it was around when I did my first one a couple of years ago. But, on my first rebuild I didn't replace the rear sprag springs and rollers and guess what failed about 200 miles later? Talked to a couple guys afterwards and was told that it's an automatic to replace those every rebuild since they're so cheap.
Is this something that the OP and the rest of us 727 newbies should worry about?
Thanks for all the advice guys. I think I'm going to give the freezer method for the lip seals a try first.
Beast, none of the old frictions were very worn at all. The rear set were all thinner (.064") than the ones from the front (.082"). The new frictions in the kit were packed in two separate groups. One set miked at .087" and the other at 0.68. So, do the thinner ones go in the rear pack or am I supposed to mix n match to get a good clearance number?
Lemme know.
Thanks.
the direct pak which is the rear drum takes the thin ones...the front clutch pak thats the thick ones usually .086 plus or minus..
The important things are to get the stack clearance into spec and to presoak those discs. I believe the thicker waffle discs can take more abuse, so they always go into the hi-drum.
I would not put the pistons into the freezer with the lip seals already on. I've never had to resort to that. But if the lip seals are frozen hard, well,that won't work.
Just use plenty of silicon O-ring lube on the lead in chamfers. You don't need to slather it in there, but make sure every sq mm of the chamfer has at least one molecule of grease on it. Then a matching smear on the lip seals.Then straight down she goes.It will practically fall in there.
But if you accidentally fold over the lip seal(it's always the outer), I have a trick.Firstly; a new lip seal can take quite a beating.As long as it hasn't split, it's good to go.Then, there is enough room in there to bias the install. What I mean is, when it is correctly installed, it is possible to move the piston from side to side, compressing the lips into the bores. Knowing this, You can start the outer lip seal by holding the piston at a very slight angle. Ima thinking 2*to 3* or so. Then push the piston hard over into the bore, and drop the other side down, gently, wiggling the high side back and forth, but always keeping the piston hard over on the low side.The final inch can be tricky, and sometimes needs help.I only use this method if I have previously folded the lip. And I put the folded part on the down side, and, in first.I never fold the lips any more!
But really, with the silicon lube, the things practically assemble themselves.
Thanks fellas.
Now I'm fighting getting the piston into the front clutch. Tried the freezer thing twice with no joy. Tried the homebrew lip wizard with no luck either. Really seems to be hanging up on the inner seal in the drum. When I take the inner seal out, its pretty easy to put the piston in working around the outer seal with the wizard thing. Put the inner seal back and it's like a hard stop. Just seems like that inner seal sticks out there too far. I've double checked it as the exact sames size as came out and made sure it was seated in its groove properly.
Inner seal should have the lip facing into the drum right?
Frustrated right now. :banghead:
Thanks Beast. I've made a decent tool out of milk jug plastic. I'll keep trying. Back in the freezer again.
