bremereric
My AC/DC clamp showed up today...It has it's own battery supply and the green button is the power button...the yellow knob is to zero it out....will test it tomorrow...
![IMG00449-20100716-1841.jpg](http://i918.photobucket.com/albums/ad26/bremereric/IMG00449-20100716-1841.jpg)
Thanks all I did was document the idea someone else gave me...thanks to themprettty kool info you have there some one will use it im sure,,,
YepSo, anything new to report? Have you taken her out and put some mileage on her in traffic?
which years???Just to throw this into the mix, I've heard that Ford Crown Vics have dual fans that push 4000 cfm and are pretty easy to modify to fit just about anything. supposedly they are very easy to find at the local you-pull-it too.
Just food for thought is all.
PM him because I don't know...just be aware that they probably pull 30 to 40 amps....that's a big concern...which years???
2006 or 2007 HHR fan at Rockauto....Eric what year of fan did you get from the HHR and what radiator are you using Diminsions wise that is. Also what wiring did you need from the HHR?
No problem that's my personality...to help...not to criticize.....and I am catching up to you...posts that is...All I can say is WOW thanks for the leg work on that.
