KitCarlson
If you think electronic advance control at this point will fix your problems .....
Checking TDC better plan.
I put it on TDC and both valves on number one are shut and the rocker will slide back-and-forth Stock rocker arms Huges pump up lifters with adjustable pushrods Whiplash Cam
OK OK by popular demand I have made a piston stop out of up a spark plug and I am in the process of trying to crank the engine over and see where it lands it’s hard because I only have a couple inches between the crank pulley and the radiator I will report back. And no I don’t want any automatic timing advance at this point all the timing is in the distributor nowIf you think electronic advance control at this point will fix your problems .....
OK guys the answer we all been waiting for. I finally got the piston stop in and cranked around enough to determine it is off by 5° I wish this was the aha moment but I don’t think it’s my problem. Now I will try the valve crossover thing that another member suggested. And yeah I did disconnect the fuel while I was testing ignition so I didn’t have to constantly flood the motor when I was trying to just look at the timing. Or trying to find top dead center I have cranked it over a lot.
When I measured the damper real top dead center Mark was 5° advanced Instead of the TDC Mark5* of what? Crank or cam timing?
wouldn't the timming be the same with a twisted cam on 1&6, but the camshaft valve timing off
Use a piston stop to confirm TDC on #1 cylinder and to properly index a timing tape marked every 90 degrees. Take the valve covers off to check rockers to see that the valves are closed on each cylinder at TDC on each cylinder.
Correct the five Degrees off wasn’t any big deal. That didn’t fix anything but it was a good thing to check it could have been. I won’t have time for a few days to work on it I feel like yanking it but I’m gonna try a few more things mostly your guises suggestions because they are all gooddid I miss something, what fixed his wont run problem? 5deg off wont give him the running issues
Seems checking valve timing on #1, and #8 could verify cam twist or not. They should be identical, but 90 crank degrees apart. # 1 at front of cam, #8 at rear, firing order 1,8,....
Me still thinks wrong polarity on pickup sensor, offsets rotor phase enough, that huge timing advance lets rotor, line up to cap terminal. Sounds like at desired timing 13-15 deg, no spark at plug, you said that.
Tried to give info of how to verify rotor and reluctor position based on spark event. Never got strait answer. You could swap polarity on pickup wires, static time it to 13 degrees give it a try. I'm out.
