SRT_DSTRHOLC
or the dyna ultra flo welded
Pypes stainless street pro with exhaust are tame until you stomp your foot into it and they are priced right aswell. Here is a link if you are interested with 2 1/2" x pipe. Andrew
http://www.youtube.com/watch?v=VvIAJmV3RMg
No sound bites, but I have TTI step headers, 3" X-pipe system and Dynomax UltraFlo mufflers ending at the rear axle. I like it much more than expected when I installed it over 2 years ago and have gotten lots of compliments from the open header racers. At idle I can hear my frame-mounted blue Holley pump, but it get pretty loud when I stomp on it. It flows pretty well because the 360 has gone 11.31 @ 115 weighing 3,540+ with unported 1.88" intake heads, .474" lift cam and 10.5 compression.
Thanks! That's the better part of the summer of 2008 spent in a 10' x 20' garage with countless dollars, lots of frustration and one pissed off girlfriend. The pypes system works well, but it was not a direct bolt on like stated in their ad. I would buy what ever mufflers you like and have your pipes custom made for your application. For me it would have worked out very similar in price. Andrew
Well guys we got back half of the pipes off and it does sound a bit louder then before. I think i can live with the results for now. Im don't have turn downs for it at the moment. The interior even with the dynamat is a lot louder but i think the turn downs it will help a bit. Thanks for all of your help guys.
Bryce/Bob
The kick over the rear end was way off and they did not line up at all with the TTI headers. I probably only used half of the system. The shop told me they could have built the same thing with less cuts for $300.00 CDN (I am not sure if that would have included the mufflers).
Is this going to pass inspection in Commiefornia ?.
Maybe I'll have to keep looking for an exhaust shop then. I haven't found any small "mom and pop" shops yet.
Andrew,that sounds sweeeett..nice car too..:cheers:
Thank you, they are the Pypes street pro mufflers that came with the kit from Summit. Andrew
That would explain (in part) your aggressive sound - and I think I like it better!
It has a stroked 511 / 400 Block in it... that might explain most of it. :love10:
how the hell? what gears and converter?
