skrews
Just curious to hear some opinions on this set up. Motor is a 3.58 stroke 360 that turns 7000 on gear change and 7200 or so out the back. Can't go wrong with the crank scraper IMO, but the windage screen is debatable. The screen should keep the crank from pulling the oil up out of the sump (Moroso deep pan). I cut off the lower skirt on the passenger side thinking the up stroke scraper will be more effective. Also thinking about folding a lip towards the crank on the driver side to make kind of another scraper.
