- Joined
- Nov 5, 2008
- Messages
- 49
- Reaction score
- 2
All I could say I have a stock block LOL
10.86@119I can't believe I get to finally make a post on this thread!
10.92@120
68 Cuda Notch
408 10.8:1
4.11's
SS springs
998
Roller cam .256 @ .050
Stage 2 port Eddy Heads by SDSS
Ported M-1 intake w/QF950
Street Car
If it weren't for my good friend Brian who goes by 408StrokerDart on Moparts I would still be chasing my tail. He tuned the car and the driver(my skills really sucked).
Thanks again Brian if you ever read this!
I hope to be posting this in the 10 second combo section soon, but for now****UPDATE*** Now it's in the 10's!!! :
360 block, 410 ci, pump gas, 10.8:1 compression
Eagle 4.00 steel crank, Scat I-beams, Diamond pistons, total seal rings (file fit),
ARP main/head studs, Edelbrock heads stage II ported by Ryan J @ Shadydell,
Small solid roller 248/254 duration w/ .576/.582 lift, Airgap (soon to be replaced w/ Victor),
Proform 750 dp (soon to be replaced w/ 950 dp),
4.10 gears, spool, 35 spline axles, pinion snubber, drag shocks front and rear
727, manual valve body, 8 converter, 28x11.5 Hoosier QTP
3250 lbs, street trim and with 3 inch Flowmasters.
Current times in sig.
.. Pump gas.I,m in!!LOL
66 Dart
410/904
8 inch Coan 4500 stall,4.30 spool,29-12-15 Hoosiers
Eddy heads mild porting
M1 with AED850HO carb(flows 930 cfm)looking into a dominator
All MSD with 6AL
cam is 252@258 .631 roller cam
Eagle H-beam 408 stroker kit .040 over pistons
Heddman Husler 1 7/8 fenderwell headers
Today I [email protected]
60fts 1.50
1/8 is6.83@100mph
WooHoo!!:cheers:
Hi, this is the other car of Gemeos Racing, a drag racer team
It is a Dodge Charger (in Brazil, Charger is different, it is only a Dart with small estetic aspects).
318 block
4 pol stroke
340 X heads
4,88 gear
4 speed manual
2350 lbs with driver
4-link suspension
fuel is alcohol(methanol)
Best E.T.
1,360 60 ft
6,6 in 1/8 mile
10,2 in 1/4 mile
PS: Sorry, I don't speak english very well
You might speak zee Engles very well, but that car is haulin ***. Nice. I mean muy bueno. lol
Thank you, in the next year, this car will go with W2 heads.
