Post your wheel and tire combos.
My Wheel ,
Front: 18X8.0 offset 25
255/40 R18 General Tire
Challenger 1974 Front disk brake
Tubular A-arm with big ball joint
Small modification of fender
Rear: 18X9.0 offset 25
275/40 R18 General Tire
8.75 rear end from B-body 62-70(track 59.2)relocate perches to 43"
0.250" cutting lip of quarter
[ame]http://www.spyncanada.com/pdf/lensod1.pdf[/ame]
74 Dart Swinger :glasses7:
Front
Wheel Brand: Thrashstars
Size: 17 x 7
Backspacing: 4.25
tire size: 225-45-17
Suspension mods: none
Rear
Size: 17 x 8
Backspacing: 4.5
tire size: 245-45-17
Suspension mod: none
1969 Barracuda Convertible
18x8 American Racing Salt Flats
5.625 Backspace
245/45 Dunlop Direzza Star Specs Front and Rear
1987 Lincoln Mark VII 8.8 Rear end
About 61 1/2 inches for the Lincoln rear. I used it because it was cheap ($200) has a 3:27 traction loc dif, disc brakes, and the axles are the same width (centered dif). An Explorer 8.8 rear is only 59 1/2 inches and would fit better with stock wheels, but the dif is off-center.
Great info, thanks! One of these days, I've got to bite the bullet and change out my 65-67 B-body rear, build one the width I need, or pony up for some custom wheels that will use the wheel wells properly. I don't know how much of a pain it will be to use an offset rear, so it's good to know the Lincoln is centered.
Thanks again!
Clair
Need to take a piece of white chalk and print "Daddy" between Hoosier. That way when to car rolls slow, it says "Who's your Daddy?"
5.625 Backspace
I've been eyeballing those wheels pretty hard...Do you have another shot - a pure side view (straight on the side, rather than a front quartering view)?
Thanks!
John
My Wheel ,
Where did you get those headlights? And hitch?
Thanks!
John
this is all I have right now, Ill get you a better one after the heat breaks!
American Racing Torq Thrust 2
Front 17 x 7 - +0mm Offset and 4 inch Backspace VN157765
Rear 17 x 8 - +8mm Offset and 4.81 inch Backspace VN157866
Tires Kumho KU31
Front 225-50R17
Rear 255-50R17
Needed a 1 inch rear spacer. Also needed to do some cutting to the front fender lower lip.
Thanks!
John
Here ya go John!
looking for a set of 15 wheels...these are Rader (Sears) flat spoke....anybody?
14 x 6 215/70
15 x 7 255/60...just lowered everything 1 1/2"
Went with Coy's C57's. 18x8 rear and 17x8 frt. both with 4.5 backspace. 235/40/18 and 215/40/17 all stock suspension. Switched the front to 225/45/17 to balance it out. still no problem with fitment.
you being in NJ,, probably know raider wheels are back being made in NJ,, not sure if they offer this rim your looking for,,,but you could get the single rib or tri rib and mill the rib off and re polish,,,,rocket also has a single rib spoke wheel it may be cheaper looks the same
Man what a transformation to your car those Coys make!!!!
Wow your car looks awesome!
I have some Coy C5's on my 61 Chrysler and love them.
Thanks for posting...
Ma Snart
Tires Kumho KU31
Front 225-50R17
Rear 255-50R17
This car is beautiful!!!!! :prayer:
Thanks! It did give it a whole new look.
Ma Snart
FRONT: 15 x 4.5 E/T GASSERS TIRES: Nexen 165-80-15
REAR: 15 X 8 ROCKET RACING TIRES: Hankook 295-50-15
If it wasn,t for a factory wheel , i would not have a MOPAR. Just me!!!!!!!! Rallys are all i ever had , along with Magnums.
