Haven't alligned the car yet, but with the engine/ trans weight in the car now I am really liking how it sits. Plenty of room off the bump stops up front, tons of clearance under the k member & reducers.
Those looks great. What rim size BS and tires are you running thanks.Haven't alligned the car yet, but with the engine/ trans weight in the car now I am really liking how it sits. Plenty of room off the bump stops up front, tons of clearance under the k member & reducers.
View attachment 1715555044 View attachment 1715555045 View attachment 1715555046 View attachment 1715555047
Fronts are 17x8 5.5BS low pad with 245/45/17Those looks great. What rim size BS and tires are you running thanks.
How wide are your wheels? Any suspension mods?Here is my 67 Dodge Dart. The rims are 18” 5x4 small bolt pattern. These are custom Budnik Rims for 5x4 lug pattern. I’m selling rims and tires if anyone is interested. It’s impossible to find great rims for a 5x4 Bolt pattern.
Did you have to modify any of the suspension?18x8 and 18x9
225/45/18 and 255/45/18
Torq Thrust M
View attachment 1715480119 View attachment 1715480120 View attachment 1715480121
1965 barracuda, rear springs are moved in but stock wheel well but running Yukon axels as they push the offset out 3/8 inch.
Rear tires 275 40r17 and rims are 17 x 9 with 5.95 back space. front rims are 17 x 8 running 225 45r17's with 10"spindles and disc brakes.
I bought these rims from American muscle, yea a mustang place but they were awesome at helping me get the right offset.
@Keith Mopar do you have a good side profile pic? These are the wheel sizes I’m considering for my 65 Valiant. What leaf springs are you running?
The springs are new for an A body bought from espo springs
did that get it onto the bump stops?I loaded about 400lbs in the trunk to try and see if the tires would rub any where.
Thanks for the reply! Are they stock height? Or did you get some for a lower ride height?
Do you have a picture of your front tires on the car ,my car has 50 series 15's came with car but to large rub need to choose new onesCar year and model - 69 Barracuda
Front
Wheel Brand - Canterline AutoDrag
Size - 15X5
Backspacing
tire size - 205-70-15
Suspension mods - none
Rear
Wheel Brand - Centerline AutoDrags
Size - 15X8.5"
Backspacing - 4-7/8"
tire size - 275-60-15
Suspension mods - springs moved in to frame rails, stock wheel wells.
Steelies: 195/75r14
Put some center caps on those steelies, and those cooper cobras with black walls out and that car would look bad ***
That's the same tire combo I run, nice fit for an early abody
