I want to put a manual steering box and column with column shift in a 74 Scamp with power steering. I need to know if a box and column from a 68 or 69 Barracuda will bolt in to the Scamp ? I know that the pitman arm needs to be changed and maybe the crank pulley. Is there anything else that needs to be done for this swap ? What other steering box and shaft would work the easiest if the 68-69 doesn't ? It has a small block and Im trying to lighten the front end up.
Thanks
Thanks
