What’s the pricing for the heads. Thanks. Kim
860/960? loaded unported, 1274 loaded cnc-ported...What’s the pricing for the heads. Thanks. Kim
Did you see on their site were they had a complete set for 860 and a set for 960 or something? And I know one set is for flat tappet and one is for roller but I don't think that's the case in this instance. I think they're both flat tappet. And also I believe there rating the flat tappet solid and hydraulic as the same spring? And then roller lifters weather hydraulic or solid with their own spring?Looks like 30 per cent off sale....
Just quoting their numbers from the internet of course I believe it was like 145 and 360 on the spring pressure and a Max of 600 lift. I thought prh also said one or two Springs were a little weak but that of course he said was if I believe you were trying to do this Max 600 lift? I'm at about a 525 lift right now with the 1.6 to 1 rockers. Which would probably be plenty for the unported heads anyways? Also if I went to a bigger cam I don't see myself going past 575..the springs are for a hydraulic roller cam. If you call you might want to ask them about the valve springs...seat pressure and nose pressure plus max lift.....I believe PRH said the set he checked the springs were a little light....
I would like to see what a basic set would do compared to the cast heads you have now. No other changes. That would be a story teller.Just quoting their numbers from the internet of course I believe it was like 145 and 360 on the spring pressure and a Max of 600 lift. I thought prh also said one or two Springs were a little weak but that of course he said was if I believe you were trying to do this Max 600 lift? I'm at about a 525 lift right now with the 1.6 to 1 rockers. Which would probably be plenty for the unported heads anyways? Also if I went to a bigger cam I don't see myself going past 575..
My wife already gave me the opportunity to compromise my big overstuffed Lazy Boy that I'm supposed to get, but I believe that was self-serving as she doesn't want that thing in her living room....Surely you can save another $300 on your remodel. You can just eat hot dogs and pork n beans on your vacation. Should be no problem buying the CNC heads.
I Know, I Know. I'm just kidding you. I know all too well about about budgets, or sometimes lack of them.
The one thing I'm guaranteed of it will weigh 50 lb less...I would like to see what a basic set would do compared to the cast heads you have now. No other changes. That would be a story teller.
I see your point, get the CNC'ed heads to keep me out of the Lazy Boy and not gain the 50 pounds on the other end! LOL....Not if you sit in that lazyboy too much. Ask me how I know!
So unless I get an open chamber aluminum head I have to have a custom thicker gasket. Like the 340s of old my Pistons protrude .010 above the deck and I need to either have open chamber heads and or a pretty thick gasket. The machine shop that put my motor together originally countersunk gasket matched my head's like .040 and you don't really even notice it. Just to make sure nothing touched. I used a felpro 1008 when I had them off as they did when they originally put it together. They wanted a bare minimum of thirty thousandths plus the .010 out of the hole and and the 1008 compressing to .039 it was just too close. That's why they countersunk a bit...I would like to see what a basic set would do compared to the cast heads you have now. No other changes. That would be a story teller.
Is this a gasket for this particular purpose?fel pro 8553pt......053 compressed.....inexpensive too...
these are fel pro cheap over the counter head gaskets. They work great for sealing. It's what I have used.Is this a gasket for this particular purpose?
Well I'm one hundred percent convinced! If that gasket can hold back what an eighteen-year-old can give to it.. I'm sold...8553 Felpro
Those are what my oldest son has on his 360. It is 11:1 with eddy heads. He decked his block so the pistons were .015 out of the hole. Although they are considered a cheap gasket He has had no problems. He put that motor together when he was 18, an he is 25 now. Motor is in his only car. driven daily.
been using that gasket for years..... for two reasons. It's what the auto parts stores give you over the counter, and they are cheap. I've NEVER had an issue with them.8553 Felpro
