Are you sure about that ? I think it's combo dependentThe TR will win. Every time.
Opinions will vary. I think you will have to be your own judge on your combo.Well really the question of the thread is are the Speedmasters an affordable reasonable head for the "average Joe"...
It's not procrastination at all, it's called patients...
It's called voice command...NO!!! It is called patience!
i
If I had to type out every word on my phone for the last five years I would have quit this form 4 years 11 months and 29 days ago...
Thank you I'm well aware of what a homophone is...Ok, we will try to be patient with you, if you don't try our patience!
what is your opinion on the CNC Speedmaster head as a budget performance head.Yep. It is combo dependent. But done correctly the TR wins every time.
Edit: now quit being a homo...lol..
lol and a ... Thats your sign I'm joking and NOT bullying..?no?My sweet wife of 26+ years can attest I don't lean that way! Stop being a bully.......................
Actually, I'm an old construction worker and it takes alot to get me mad. Picking at and laughing at each other is what gets some of us through a tough days work. I figured that of all the people on this site, you would be the one I could pick on for spelling!
Concrete forman for most my work career, but have done seemingly just about everything...
Voice command saved my bacon. I couldn't spell my way out of a wet paper bag.... I'm damn near a math wizard, but spelling just don't add up!... Sometimes y? Who makes this stuff up!??
I'm really working at a small budget for aluminum heads. At the very least I should be able to get the bear heads with no CNC and slowly get parts for them.
I'm just trying to wait for the right deal.
Confuscious say : NEVER MESS WITH CONCRETE WORKER !!
I`d do cnc anyway, well worth the $ in the long run !
Isn't the concrete foreman the guy wearing the hard hat and shiny new boots holding a clip board in one hand and coffee in the other. lol
Why the disagree j par, couldn't afford the new shiny boots? or didn't get to hold the clip board.
Big block Chevy ? or stroked big block Mopar. any flow #'sTypical of what you see anymore. Big, blown out bowls and a runner too small to feed it. Oversized valves to fill up the huge bowl.
Last set I did was for a big block. It actually went almost 900 on the dyno which was over a hundred more than I guessed. I had the dyno sheets faxed to me and the numbers looked legit. And the time slips matched what the dyno said.
As far as casting go, they are fine. I've never seen a set of heads like that that don't need a valve job. With a bowl that big, they get a 50 degree seat.
The issue is always the same. You are still using mid 1969's architecture. Without offsetting the intake rocker (and maybe the exhaust...I think the last time I looked at my W2 junk I was thinking about an offset exhaust but why I thought that at the time I don't remember) and raising the port, you are stuck. The small CSA makes air speed go through the roof, so you do things you don't normally do to control it. Everybody and their mother thinks the faster the airspeed the better, but that is just not the case. You need to CONTROL the air going through the port (or, picture the head moving through the air...) and sometimes, more often than not, air speed is your enemy. The flow bench will tell you the port loves airspeed. Sometimes you have to ignore the flow bench. Especially on the exhaust.
Stealth heads are 499.00 each brand new assembled. IQ52 has thread on them and said they are a pretty good head a budget after some checking and a little bowl work to get the flow up to the advertised #'s.A pair of big block 440 source stealth heads and rockers in great condition came up for sale for $1, 100 locally because they're going to trick flow....
I know I don't need big block heads but this is the vacuum I'd like to get caught in.
Those are numbers he had before he cleaned them up. I believe he got 20cfm more after cleanup.The four sets I’ve had on my flowbench max out at 267 cfm. So many better options out there now for big blocks.
