j par
Well-hung Member
You sure about that?
Might want to double check those specs.
At the cams highest lift..?You do know what the term “over the nose” refers to, right?
So....... installed at what height, and at what valve lift do you achieve 382lbs over the nose with that spring?
Captain Obvious what do you think I'm doing!?... I'm not running down and trying to bang a Sheep, I'm trying to walk down and bang them all...I think you should do a little more homework on spring heights and loads.
I'm "assuming" like cam manufacturers giving a @50, there's a general lift there giving these numbers ?..
I’ve told you exactly how to do it, but you want to go about it some other way.
My way starts with you finding out what the spring requirements are for your current cam.
Either call the cam grinder and ask them, or measure the installed height of the springs that are on the motor now(this assumes the current springs are set up correctly for the cam) and look at the chart on the Crower site and see what the loads are for your spring, at that installed height, and your lift.
To illustrate this point consider two springs that have approximately the same seat pressure at 1.800-inches installed height; one at 123 pounds-per-inch and the other 124 pounds-per-inch. The spring with 123 pounds-per-inch seat pressure has a rate of 408 while the spring with 124-pounds-per-inch has a rate of 251.
Well there you go Jpar,if you can wait that long!.If he wants me to look at his heads when I come over I will. Just costs him a 24 pack of Safeway ginger ale.
And he has to wait until December. I ain't coming over before then unless it's an emergency.
The heads are still in their boxes on the Shelf where I put them the day after I got them. One thing about me I've always figured there's a few different ways to skin a cat... (Clutch tamer).. if I had my mind completely wrapped around this I would have stopped asking questions.I’ve told you exactly how to do it, but you want to go about it some other way.
100% my money my car my way or the highway...Dwayne, what you'll figure out is that a lot of times jpar isn't looking for the right answer, just for reaffirmation on his way of doing things.
I'm not beating on you jpar, but I've read a bunch of your posts over the years and most follow the same pattern and this one is no different.
Post 987 - my way of skinning the cat didn't even get noticedI'd hate to be that cat. lol
cause he's scared. lol He's getting advise from those who build high end stuff.Post 987 - my way of skinning the cat didn't even get noticed
Like I said I got a p.m. with the other half of the puzzle...There’s really only one right way to set up heads....... which is to match the spring loads in accordance with the requirements of the cam profile, along with all the matching components, and desired rpm range.
THanks YR for the PMLike I said I got a p.m. with the other half of the puzzle...
Shoot.... just check that the valves are sealing, if not lap 'em. Your cam isn't THAT big. If those springs that came with those heads won't take a .520 lift, then Chopsticks to lamb chops! I say run 'em!
I'd skin the cat your way if it was some junkyard 318 or 360 but it's not...
I'll be disassembling and checking the spring rates you can Bank on that...
Not saying I won't put it all back together and run it, just I will check things out. It's basically free to take them apart and take them down to a shop..
Anyways don't you have a van to buy...
and pretty soon you'll have 7k into two dusters and a van that don't have enough horsepower combined to get out of their own way....
- It's a soon to be 7k stroker, I get it
- check'n spring rates is a good idea. Peace of mind...
- Look'n, been look'n for a van. Like always, they are everywhere till poor ole' 318alreadyhaswon wants one....
