Actually been too busy working on customers cars... Doing a hackle wacko on this 65 Malibu console to make the ramrod fit..Don’t rush him. He’s retired. And old. And needs 2 naps a day. He will get it done on old people time.
easy there tiger I just got the heads back yesterday and my cometic gaskets were there when I got home. I'll try and get the radiator dumped tonight and tomorrow get started as I want to pull the engine and tranny out as well. I want to check my clutch and I've got the new headers to install and I do not like to install them with the engine in so I might as well take it all out and do it right on my engine stand get everything all adjusted...Are you done yet. Is it running
Sorry my friend real life didn't happen that way LOL..
Stay tuned right here I'll keep you guys posted..
You should push the button before you pull the engine to swap heads.Actually been too busy working on customers cars... Doing a hackle wacko on this 65 Malibu console to make the ramrod fit..
The tracks aren't open.. I can get a big enough ticket to get arrested without the damn nitrous...You should push the button before you pull the engine to swap heads.
Pulling the engine to work on it is a bad omen in my book. lol
Sounds like your nitrous bottle has been sitting in your spare bedroom so long it's starting to leak.. wait a minute it's never been installed.....Pssssss pssssssssssssssssss
So you would rather oil down the track than on a back road. lolThe tracks aren't open.. I can get a big enough ticket to get arrested without the damn nitrous...
It is more likely the nitrous will be used until the bottle needs refilled. It kinda fits your attention span. always what can I do next. lol
There you go wacken the nest again!Pssssss pssssssssssssssssss
you need a lego car..... something you can tare down and build again twice a weekView attachment 1715533977
Done for the night...
It pretty much is.. almost all of the wiring unplugged and I'll probably be redoing some of that as well making sure it all plugs in and unplugs.. both of the nitrous plugs unplugged. The coil unplugged, the distributor unplugged, the fuel pump wires unplug, the fan wires unplugged, and the 12 volt feed for the electric choke unplugged which I don't use...you need a lego car..... something you can tare down and build again twice a week
I think I can...
He is pulling motor and tranny. Wants to check the clutch also. Kim
Its Call "Pssssss pssssssssssssssssss".........ProcrastinationOk...help a brother out. If you are changing heads, why is the shifter off?
Just asking...
