I'm not sure to be honest Matt. It looks right? I'm shitty at documenting stuff lol and at getting it done too.
Thank you!!!I went downstairs this AM to take a closer look at the Barracuda script on my brother's '67 notch. The face of the script is chromed and the sides are black.
Any suggestions on the adhesive, if any, to hold the colored lenses? (Hi beam and brake indicators)
I don't recall those being staked. Well I have lots of pics. I'll see if I have any details for those two.I think I used some of the plastic from the factory plastic stakes. Been a while tho lol.
Looking good Matt.
Thanks.Oil pressure gauge looks reading too high. They are just basic range indicators but... in calibrating approx' 60 psi should be at the 'U' in PRESSURE. Not sure why I can remember that when I can't remember what the center test point of 23 ohms was equal to in PSI. I'll go to the book later today.
I would get the gray wire off that sender now. Could be overheating that gauge.Thanks.
I agree. Even cold start up, that's high. If you recall I tested the gages, so I suspect the replacement sender.
I have a new sender from Bill Rolick that is supposedly correct but wasn't able to swap it in yet.
It would be good to test the new sender for pressure vs. resistance. Have come up with a way to do that.
Home made spring-type mount that slips on the dash lip. At first I worried about it passing tech at the strip and for SCCA autocross and had fishing wire running right and left. But its proven to be pretty snug in there and no issues with any techs.looks good, what did you do for the tach mount?
After warming the oil up to 170ish F, oil pressure dropped to just above 6th mark.I would get the gray wire off that sender now. Could be overheating that gauge.
edit; Curiosity got me so went to look... 23 ohms on this gauge is 40 psi +/- 5. and you gauge is now showing well over 80 psi which is as far as the scale/chart goes.
