Toronto Island Airport - CYTZ - Ontario Canada
Pinto "body" with SBC?
An EV conversion?
and that grass looks really dry.
I have been doing industrial work for 34 years. I used to work 480 hot but not anymore. If it is not a life safety system, Its getting turned off. I have had m,y share of close calls and been hit several times with 277V. To close to retirement for the crap anymore.In the 50 years I was an electrician I got it about 6 times each time seem to be worse so after that we started to shut down all circuits we were workin on but sometimes you have to work it hot especially in under ground garages got to see what your doing but it was the best paying job I ever had
I bet those made the surveyors and grade checkers nuts!
tell me about that stuff , needing to do mine again ....BobI put down a fresh coat of epoxy driveway sealant. It is now fully cured after 48 hrs since it was applied. This stuff is as tough as nails. It should be good for another 7 years…or more.
The driveway is open for business again!
