greymouser7
Vagrant Vagabond “Veni Vidi Vici”
- Joined
- Apr 17, 2010
- Messages
- 3,729
- Reaction score
- 1,457
i am looking at avs2 Edelbrock carbs on Facebook marketplace
That model has not been out long so the odds are in your favor. I would ask the seller why he is selling it, if it had problems ect. You can download the tuning chart from the Edelbrock website and parts are plentiful.i am looking at avs2 Edelbrock carbs on Facebook marketplace
you wanted to be pretty much stock the way it came or nothing Beyond a jet change.... and very important here, that the throttle shaft is not loose and wobbling in it's bushings. That will give a lean spike to the nearest cylinder and under wot as it climbs the rpm....blamo...things break.i am looking at avs2 Edelbrock carbs on Facebook marketplace
Pretty hard if you cannot take it apart. I have a VERY nice (externally) Ed AFB that is a mess internally. Doubt I will ever get it straightened out.
$200, bolt on and adjust I guess, but without any adjusting experience. ThanksWhat are your expectations for a used carburetor? To bolt on and go? How much are they asking?
-thanks I actually forgot about that.If you don't have a fuel pressure regulator plan in installing one with the install.
I have followed your posts here along with others on FABO and assume you would recommend a 750 double pumper, either Holley, Quick Fuel, Holley-based Demon, or something along those lines.Edelbrock carbs=garbage!!!..much better carbs out there to buy!!
Sorry; gotta disagree. I have had big problems with a few Holleys, and have had amazing good luck with Eddys. My modified 340 runs like a top with the 650 Thunder series and will roast the tires.Edelbrock carbs=garbage!!!..much better carbs out there to buy!!
I totally agree. New ones are not all the expensive. Plus think about this. If you are going to use it to test and tune engines, I would want to start with a known good carb.That's a lot to pay for a used carburetor when you could put half again with it and buy new. DO it smart.
For what you are doing an AVS2 would be the perfect carburetor. You would want the 650 or 800 for the size of your engine. Don't waste your time buying used, just buy a new one. Don't forget to buy the insulating gasket that goes between the carburetor and the intake to prevent vapor lock and other negative issues. You don't need a return line for this type of install, just a good regulator. I set mine at 4.5#'s then moved it to 5#'s for my street motor. I think I paid about $200 for my wide band and if your are setting up an engine run test stand it will be the cherry on top for knowing what your motor is doing with respect to air/fuel. The Edelbrock support is pretty good and there are lots of videos to help. Your build sounds interesting, good luck!I am going to be assembling & breaking in some 360’s over the next year, sense I have some time to work my project cars & collection of parts.
I bought a running ( I watched on test stand $250) 1978? 360 engine to test my wiring, and carbs, etc. on for these roller project cars so I don’t test a prepped engine build with break-in with unreliable, parts-achieving that 20 minutes, variable > 2000RPM break in without interruption.
Which is how I would test the carb, but I don’t have any experience tuning. Will probably buy O2 sensors and anything else (how expensive is a wide band??? Sensor) needed against reasonable cost.
Am looking at the Edelbrocks as a low maintenance, all around carb, living under the often suggested gossip: “Holley’s need more adjusting.”
Isn’t there 2 different ways to setup/buy the pressure regulators? With or without return line-the first being much more expensive?
6 psi correct?
A double pumper would go alright with the manual transmission cars I have, but I have no experience tuning, and only one car will be all out performance-the others will be freeway drivers, in hot traffic- stop and go 80, stop and go...
I did get a 3310 or is it 3311 and will try it out to, but want to try one of the new Edelbrocks.
New in box, new carbThat's a lot to pay for a used carburetor when you could put half again with it and buy new. DO it smart.
No sirDo you know how to tune a Holley properly???
Here's the thing - there is no load on the engine when run on a test stand. To do what you are asking just needs a carb that works from 0 (idle) to maybe 20% throttle opening. You need a 4 bbl mostly cause it will match the intake - might as well be the same configuration.I bought a running ( I watched on test stand $250) 1978? 360 engine to test my wiring, and carbs, etc. on for these roller project cars so I don’t test a prepped engine build with break-in with unreliable, parts-achieving that 20 minutes, variable > 2000RPM break in without interruption.
No. Test the carb on a something else. Break in is not the time to find float stuck or gasket leaking.Which is how I would test the carb, but I don’t have any experience tuning. Will probably buy O2 sensors and anything else (how expensive is a wide band??? Sensor) needed against reasonable cost.
I'm not old but old enough to think 200 is a lot for a used carb.$200, bolt on and adjust I guess, but without any adjusting experience. Thanks
6 would be good, 5 would be good, 3 would be OK but at idle low for a mechanical pump.Isn’t there 2 different ways to setup/buy the pressure regulators? With or without return line-the first being much more expensive?
6 psi correct?
Probably a List 3310. You could use it.I did get a 3310 or is it 3311 and will try it out to, but want to try one of the new Edelbrocks.
First investment should be to buy a cheap (used) copy of Urich & Fisher.No sir
I am pretty good with carburetors. It wasn't a matter of tuning. I just had mechanical problems with them. It's kind of like when I paid through the nose for Michelin tires on a Jeep Grand Cherokee several years ago. The vehicle went from riding like a dream to riding like a lumber wagon. Plus, they didn't last nearly as long as the Goodyears they replaced. And with a considerably higher treadware number, I expected (and was promised) better. And before anyone wants to tell me that you cannot specifically compare exact treadware numbers between brands, I know that. But I went from about a 400 to about a 520, so I should have seen an increase in tread life. To this day I would not even consider Michelins, and I know a lot of people really like them. If a person has more than their fair share of problems with any specific brand of a given item, they will not like it no matter how many others swear by it.Do you know how to tune a Holley properly???
