comp cams 1420 scroll down the page I will get the mancini cataloge from work tomorrow.
Comp Cams' Magnum Roller Rocker Arms
street performance roller rocker, excellent upgrade from stock
COMP Cams, Inc.® 3406 Democrat Road Memphis TN 38118 US 1-800-999-0853
Click Here For Printer Friendly Version Click Here For Printer Friendly Version Click Here For Printer Friendly Version
Magnum Roller Rocker Arms (U.S. Patent No. 4,961,407)
COMP Cams® Magnum Roller Rockers are the ultimate street rocker. Thats because they were designed with the serious performance enthusiast in mind. They will help your engine make more power and last longer. Magnum Roller Rocker Arms are:
STRONG
Magnum Roller Rocker Arms are made from 8620 chromemoly steel. This makes them stronger than die cast aluminum or stamped steel rockers. This superior material, along with the Magnums super stiff design, assures maximum lift because this rocker arm will not flex.
ACCURATE
You cant get maximum horsepower from your engine if your rocker ratio is off. We checked other rockers and found rockers that were as much as .040 short on lift. The Magnum Rockers are super Accurate. They check dead on every time.
POWERFUL
The Magnum Roller Rockers can make between 15 and 30 horsepower over other rockers! Why? The secret is that not only does the roller tip reduce friction, the Magnum Rockers incredibly stiff design and super accurate ratios yield more effective valve lift.
DURABLE
The roller tip design reduces friction by not scrubbing the valve end or pushing the valve stem hard against the valve guide. This in conjunction with super strong design of the rocker makes for a simple, bulletproof, and cost effective combination.
Magnum Roller Rockers can be used with all High Energy, Magnum, Xtreme Energy, Nitrous HP, Xtreme 4X4 and Xtreme Marine Camshafts as well as any other hydraulic or solid cam WHERE OPEN SPRING PRESSURES DO NOT EXCEED 350 lbs.
Part # Application Rocker Stud Ratio
1416-16B American Motors V8 3/8" 1.6
*1412-16 Chevy V8 265-400 3/8" 1.52
*1412-12 Chevy V6 200-262 3/8" 1.52
*1413-12 Chevy V6 60° 173 10mm 1.52
1414-12 Chevy V6 60° 173 10mm 1.6
*1416-16C Chevy V8 265-400 3/8" 1.6
*1416-12 Chevy V6 200-262 3/8" 1.6
*1411-16A Chevy V8 396-454 7/16" 1.72
1417-16H Chevy V8 265-400 3/8" 1.52
1418-16H Chevy V8 265-400 3/8" 1.6
1420-16 Chrysler V8 273-360
(shafts included) Shaft 1.5
1411-16B Ford Boss 302, 351C-400M 7/16" 1.72
1431-16E Ford V8 289-351W
(Rail Type) 1968-89 3/8" 1.6
1450-16E Ford V8 289-351W
(Rail Type) 1968-89 3/8" 1.7
1442-16F Ford V8 289-351W
(Non Rail) 1961-67 3/8" 1.6
1411-16B Ford V8 429-460 7/16" 1.72
1442-16G Oldsmobile V8 260-455 3/8" 1.6
1451-16 Pontiac V8 265-455 7/16" 1.52
1452-16 Pontiac V8 265-455 7/16" 1.65
1079-2 Shafts for 1420 rockers N/A N/A
Call 1-800-999-0853 For Sales
Characteristics
# 15 to 30 horsepower direct bolt on over stock rockers
# Precision ground Roller tip to reduce friction and Valve Guide/Valve Tip Wear
# High strength investment cast 8650 chromemoly body
# Pressed and Swedged axle for Long Life
# COMP Cams® Magnum Rockers are identifiable by the logo directly cast on the body itself, insist on the best and accept no imitations
# Long slot for high lift cams
# Super accurate ratio directly cast into the body
# Applications include street performance and excellent upgrade from stock
More Information
# Rockin' and Rollin' Rockers - Popular Hot Rodding
Chart Footnotes:
A. Use stud 4514-16 to replace late model pedestal
B. Must have screw in studs and guide plates
C. May require machine work to the cylinder head
E. For 78-Present use with 4504-16 studs. Not for use with guide plates.
F. Also can be used on heads with guide plates.
G. Other parts required see page 291
H. For use on 1987-later self aligning.
Note: Rockers available as singles, half-sets and full sets.
*50-state legal for 1993 and older GM vehicles equipped with 200 c.i.d. (4.2L) to 454 c.i.d. (7.4L) gasoline engines. C.A.R.B. E.O. #D-279-4.
