RAMM
Pushrod length check. Thrust clearance came in @ .006". Monday the rings get filed and the JE pistons go on the rods. J.Rob
I HAVE A NUMBERS MATCHING 340 SITTING IN MY GARAGE how much value if any is lost if i put in new forged. crank rods and pistons when I rebuild it , all quality parts engine has been sitting in a temp and humidity controlled garage for 15 yearsPushrod length check. Thrust clearance came in @ .006". Monday the rings get filed and the JE pistons go on the rods. J.Rob
I settled on this little guy for camshaft duties.
Comp 20-309-4
Magnum Muscle
Camshaft Lifter Style
Hydraulic Flat Tappet
Advertised Intake Duration
268
Intake Duration at 0.050 in
222
Advertised Exhaust Duration
276
Exhaust Duration at 0.050 in
226
Intake Lift
0.464 in
Exhaust Lift
0.464 in
Lobe Separation Angle
110 Degrees
Operating Range RPM Lower
1800 RPM
Operating Range RPM Upper
5800 RPM
Manufacturer Grind Number
268AH-10
Material
Cast Iron
Color
Natural
Finish
Natural
Quantity
Each
Note
Hydraulic Flat Tappet - Magnum Muscle: Factory I.D. #2899206
J.Rob
Thanks then i'll do it and keep all the old parts to sell with the car-engineI say zero. No one would know. Until they opened up the engine many years from now.
You could put a stroker in it and no one would know.
Well... maybe until they drove it.
been there done that , at 100 + miles a day i'm looking for a little better gas mileage maybe i'll upgrade the parts to get maximum mpg as it is now i use 3/4 of a tank daily , i want to go 3 days before i have to put gas in the tank . tired of putting gas in dailyYou could put a stroker in it and no one would know.
Reduce the cam size down to or close to the 2bbl. cam and add 2.76 gears for the long Hwy. trips. Everything else will be in the tune. I found the MSD to be helpful in adding mileage as long as the rpms stay below 3K.
I've gotta pretty big update to share. I was able to get this little stock stroke deal together finally AND get it on the dyno for breakin and a few prelim testing. I did use some sweet Trend pushrods in 7.400' x 8 and 7.450" x 8 due to the exhaust valves being a little longer which came in today. I'm working on a video to show some of the break in process that I like to use. For now here it is in all of its #'s matching glory. J.Rob
Ok, I’m a bit confused. What is the 8 part of the pushrod...the diameter? Never used Trend so maybe they have some other way to call out diameter.
8 of them are 7.400" OAL and 8 of them are 7.450" OAL. Both are 5/16" x .080" wall. J.Rob
that sounds about right390 hp 410tq
390 hp 410tq
