Sacebird supplies the brackets and a couple of miscellaneous parts. You source the rest of the part online or through a local auto parts store. I ordered everything for mine from rockauto.com
The Calipers are Chevy Celebrity and the Rotors are Toyota Previa. If you want to keep your 4x5 bolt patter you will need to drill new holes into the rotor, or have a local shop do it. Scarebird also sells pre drilled rotors. The hardest part is removing the drum from the hub and cleaning up the surface of the hub so the rotor sits flush. Otherwise it is a rather simple bolt on conversion.
BTW: My parts estimate of $330 included $60 for a Dual Master Cylinder as I upgraded that along the process. I also paid more for Raybestos parts rather and some of the cheaper or "off" brands. If you really wanted to go on the cheap you could do it for less than $250.
Driving impressions: VAST improvement over 9" drums! Stops smooth and straight effortlessly. Very happy with them.
The scarebird web page is
www.scarebird.com they sell kits for both 9" and 10" drums.
Curt.
