Show your 5x4 small bolt pattern wheels!
Still trying to figure out a rear tire size, hopefully get them mounted this month though
UGH!!
The fronts I went with 205/70R14 and am very pleased
Rears mounted up
245/60s
I got a set of 4 of these 14x6” deep dish steel rims on an old project car I bought. I thought they were cool, so I had a couple dechromed and painted to match the blue car. Put them on the back for a little wider look.
A member on here.....I don't know the DOT date code off hand
They have 0 miles on them
I couldn't find anything other than BFGs locally or online
Auto-Drag Center Lines since 1987
275/60/15 Back
215/60/15 Front
I am currently in the process of upgrading to 5/4.5 and will be going with stock steel rims for a different look in 2021
dart dave i'm wanting to match either one t70r or t70 and if you find some i'll buy the other one from you , lol and i'll do the same .
Just put these shoes on. Have the original steelies with dogbowls still if anybody is interested. Sandblasted and ready for powder or your choosing!
Same tires and wheels I have on mine except the RWL are turned in. I'm thinking I might want to turn them out. Yours look pretty good that way.
275/60/15 Back
215/60/15 Front
I am currently in the process of upgrading to 5/4.5X4" and will be going with stock steel rims for a different look in 2021
That was my plan as well, However a set of "old" polished 15x8.5 x4" with 4.5 BS presented themselves to me free of charge! I like the Centerlines.
These are no worse than my current wheels were, that were on the car since 1986. They polished back up just fine and Just needed the right polishers to finish them. I wore the other polishers out for my originals! My fronts are 15x3.5 though and the rear are 15x.8.5x4" with 3.75 BS. When finished I will swap my tires and tuck it in!
Fronts are 14" X 5 1/2" Rallyes with P195/75R14 tires (factory backspace).
Rears are 15" X 7" WheelVintiques Rallyes with P245/60R15 (4 1/4" backspace).
These are no worse than my current wheels were, that were on the car since 1986. They polished back up just fine and Just needed the right polishers to finish them. I wore the other polishers out for my originals! My fronts are 15x3.5 though. When finished I will swap my tires and tuck it in!
Those look good! What did you use and how did ya do it? :thankyou:
Mothers Power Ball Mini and Mothers Power Cone work the best. The big power ball does not get in tight.
Mostly mothers polish. Some light wet sanding with 4000/6000 speeds it up.
Final Polish and routine maintenance, I use a product from Chrome-It with a terry cloth and microfiber cloth.
Mothers Power Ball Mini and Mother Power Cone work the best. The big power ball does not get in tight.
This was after about 15 minutes with the large Power Ball only. It does not get around the Rivets well. And these were Original Polished Wheels not Satin.
I used these in 2012 to get my originals shined back up, and after all 4 wheels they were wore out and tossed away!
Excellent! Thank you so much! Now if I can just find the center caps Ill be in business! lol
I gave up trying and got the crappy replacements. Ordered some custom Logo sticker pads to replace the Centerline ones.
This is the maintainer. It keeps the Fish Wheels and the Coach’s Alcoa’s + the Ram 3500 Alcoa’s looking sharp. 8 once’s has last me for than 5 years!
