Rockerdude
Rock n' Roll and A-bodies
Maybe if someone could possibly make a 4 valve head work without making it a DOHC, maybe similar to the cummins 24 valve?
That bunch over there kinda reminds me of the last group of cavemen that refused to accept the wheel and fire because they were afraid of it, while all the other cavemen in the world had evolved to new heights with those new found inventions. Their lose, not mine! They may never know or realize what was being offered to them at the time....I remember that....kind of a gut punch eh? Kudos for the effort. A long stroke small bore aint the best starting point.
It certainly seems like They'd rather keep control of Their "secret club", & discourage "outsiders" from contributing advances &/or exposure, then spend countless posts whining about the scarcity of aftermarket support. There are many there interested, but have been let down in the past, & have a negative mindset towards a new head.That bunch over there kinda reminds me of the last group of cavemen that refused to accept the wheel and fire because they were afraid of it, while all the other cavemen in the world had evolved to new heights with those new found inventions. Their lose, not mine! They may never know or realize what was being offered to them at the time....
Agreed, but moving the alt to the drivers side could free up some access to the dizzy.
The cylinder and bolt hole spacing for a Ford 4.6 Modular engine is really close to that of a Slant. Over lay a 4.6 Head gasket over a Slant and you will see what I mean, not exact, but probably as close as one will get. This is a cross flow 4 valve OHC engine. So you won’t be messing with push rods, you will need to figure out a belt to turn the two front cam pulleys. Anyone going to this much effort would also go with a crank trigger and an external oil pump. The existing distributor and oil pump could be eliminated. Seems doable. Sectioning, adding spacers and re welding the v8 heads to make an I6 should not be a problem for anyone with a boat load of money.So is there a known aluminum V8 head with the same cylinder spacing? I guess it seems all for naught when you then have to figure out weather the pushrod geometry is correct. Fun to think about.
Still planning on adjusting points with Your new crossflow head? Lol!Well, I for one do not believe there is room for a cross flow head. No how, no way. An intake on the passenger's side would totally cover the distributor making access all but impossible. Screw that noise.
Sure, & a custom inline 6 cam made from scratch etc.,etc., I'm sure there will be people falling over each other to build that knowing how they're constructed, probably have 30% of the cost of a billet head getting that made. Working out coolant flow, oil feed/drainback, & are We piggy-backing the OE cam&sprocket to drive this OHC? Boatload of $ indeed!The cylinder and bolt hole spacing for a Ford 4.6 Modular engine is really close to that of a Slant. Over lay a 4.6 Head gasket over a Slant and you will see what I mean, not exact, but probably as close as one will get. This is a cross flow 4 valve OHC engine. So you won’t be messing with push rods, you will need to figure out a belt to turn the two front cam pulleys. Anyone going to this much effort would also go with a crank trigger and an external oil pump. The existing distributor and oil pump could be eliminated. Seems doable. Sectioning, adding spacers and re welding the v8 heads to make an I6 should not be a problem for anyone with a boat load of money.
So anyway, for a modern head that is really close to the slant six spacing, look at a Ford 4.6
Yes, an original factory(one of several that are still floating 'round) one. Steve Magnante had Doug build His one&only all Al-U-minimum for a retro-race Toad. They are rare, basically iron head copies, and would actually reduce output unless the compression were raised one whole point(9:1+).wasn't there a /6 aluminum head out there floating around for some ridiculous price not long ago?
Yes,the right head would be worth the cost, & there is only 1 real con with FI...initial cost...i love innovation, n folks who refuse to give up. would the ends justify the means? i my case i would want a alum. head for better flow n weight saving. at what cost? alum block has head gasket issues so no on that. FI has its pro's n cons.
