thebearded1
Thanks the exhaust is bbq paint and the intake is Rust-Oleum AluminumI really like the color you picked out.
Yup slant six valve springs figured it would be best to match the powerplant hahaAre those valve sprAngs you're using on the friction shocks?
Very creative. You think they're gonna work good?Yup slant six valve springs figured it would be best to match the powerplant haha
They should. The Andre Hartford shocks are now offering this plastic friction disc for their shocks. That will take some adjusting to fine tune but that just means more reasons to take the car out. They won't be as good as tube shocks but that would ruin the look for the type of car.Very creative. You think they're gonna work good?
Yeah I love them. I think they're very period correct. Will you grease them or run dry?They should. The Andre Hartford shocks are now offering this plastic friction disc for their shocks. That will take some adjusting to fine tune but that just means more reasons to take the car out. They won't be as good as tube shocks but that would ruin the look for the type of car.
This plastic is pretty slippery so I shouldn't need to grease themYeah I love them. I think they're very period correct. Will you grease them or run dry?
The throttle shaft was heavily worn as well and would have cause leaks on its own. If the shaft was decent I was going to add bushings to the base plate myself.a good carb guru can drill out your 2 bbl throttle shaft and put bushings in it and stop them vacuum leaks,..folks been doing it for years on all sorts of carbs!!
Nice project!Making some slow but steady progress. I made a bracket setup for the throttle and kickdown cables and the return springs. The 2 barrel carb drives nice and has a lot more pep. The next warm day I will take it down to my "testing grounds" and use the Drag Racer app to see if i turn a better 1/8 mile time.
I made a bracket for the seat belts too. It's hard to see in the photo but it's 1/4" steel with gussets for the tabs. There is another piece of 1/4" steel the same width and length on the backside of the body. The 2 pieces sandwich the back body using 7/16" grade 8 bolts. Later on when I add a roll bar that is tied into the frame i will tie this bar into the roll bar. I'd eventually like to run this car at one of the Loring Timing Association's land speed events in Maine to see what it will do which is why I want to add the rollbar. I will have 4 point seat belts in it by then too.
Last night I upholstered the seat back. It's 4" foam with badding attached to 1/4" birch plywood. I will screw another piece of 1/4" plywood to the body and use velcro to hold it in place. I was even able to get the stripes to line up! Now I'm going to make a thinner pad at the top to help fill in the gap between the body lip and seat back. It will be 2" foam and tan fabric.
It has to be a very long reamer with a pilot bit or set up in a honing machine as the 2 holes have to be aligned exactly so the king pin slides through.wheel cylinder hone?
