Marcohotrod
Then you need to look at the area a dry sump has.
You can't get enough area on the suction side of the pump. This has been published for decades.
sucking air with a wet sump is not good. a dry sump has many suctions cuz they HAVE A BIG TANK that the oil and air is sucked into and stored with baffles, then the oil is sucked out the bottom and pumped in to the engine. what is the i.d. of the new dipstick tube cuz it does not look much larger? and mopar and canton and moroso use a screen on the pickup cuz it is around 85% open and 15% metal, where the restrictive milodon intake with a bunch of drilled holes is a "nice restriction"-Smokey Yunick - 50% open and 50% metal
