So they weren’t lying…
75slant6
Russellville, ky
We’ve all heard people say “they’re still out there” followed by photos or stories of some some awesome find in a barn, garage or fence row. Well, I’ve always been happy for the people who make these discoveries, I just never thought I’d have one of my own. Today I was doing some storm repair work for a lady that we’ve worked for in the past and after repairing a roof on an old barn I went around back to take a piss. While standing there, I peered in through the gaps in the boards and saw two engine blocks and a few heads laying on the dirt floor. I could tell from the exhaust ports that they weren’t sb Mopar but decided to go check them out anyway. I looked the one block over, then flipped a head over and noticed the hemispherical chamber! I whipped around and saw a big valve cover with 4 holes in it, leaning against the wall! Quickly walked over to it and saw the iconic “Chrysler FirePower”!! Then came the shakes of excitement! I asked the lady I was working for if she’d like to sell the engine parts in the barn. She didn’t know anything about them and asked me to show them to her (it was her parents place that she recently inherited) after looking them over she said “if those interest you, you can have them!” I offered multiple times to pay for them but she insisted I take them and anything else in the barn that I might want. (It was mostly empty so nothing else there that I wanted) From what I have gathered so far, the bare block is an industrial 354 Hemi, as for the intact shortblock, I’m 99% sure it’s a 392!!!
She asked me later if I knew what vehicles they were from and I said a Chrysler. She said someone must have given them to her dad since he never had any Chrysler vehicles, he was a Ford man.
There’s no telling how long these parts have sat in the dirt floor of this barn, but I’m going to have fun cleaning all this up because everything that SHOULD slide, rotate or pivot must definitely does not!
And since threads (especially ones like this) are worthless without pics, here’s what all I got.
First up, the engine blocks. As I said earlier, the bare block is an industrial 354 and the short block I’m almost for certain is a 392.
Next up, we have a standard 4bbl intake and the industrial intake along with a set of head (not sure which number these are)
In total there were 3 sets of heads. 1731526 392 heads, 1635779 desoto heads and 1556157 heads.
Here are the 2nd and 3rd set. Set with the drool tubes are the 392 heads.
I also got all 8 rods and pistons for the 354. I’m pretty sure someone had started rebuilding this engine but never finished, if you zoom in on the 4th piston from the left, the ring is brand new! Now these will obviously need to be redone since these pistons are all stuck in the position that they’re in.
Two sets of rocker arms, all stuck where they are. Oil pump and an oil pan.
Two distributors, 2nd oil pan (one of them has a hole rusted in it) only have one valley cover but have an extra front cover/water pump housing.
Did I mention everything is stuck? Here’s how I found the 354 timing chain. I couldn’t even move it! :rofl:
Next we have the 354 crank and the two sets of valve covers.
And lastly, a photo of the awesome, iconic FirePower valve covers!
Yup. There are a lot of things of vintage Mopar, cars & parts, to be had CHEAP, even FREE. It helps if you know someone or someone you know, knows someone. I've got some very cool & very hard to find pieces this way. Now I'm just waiting for that Mopar car or truck to come along. It IS still out there. Good find 75slant6.
Years back Logan airport auctioned off some old equipment. He bought a lugguge cart powered by a Hemi with less than a 1000 miles for $100. Motor was mint. Not sure if it was a 354 or 392.I love finding deals.
You know, that actually could have been the case!
Looks like 1957 341 Desoto stuff with the Chrysler stuff. Pm me the casting numbers and the numbers on the top of the blocks near the valley pan and I'll help you sort your engines and parts out.
I’ll have to get the block numbers when I get them unloaded off my truck.
Cool find! Have any plans to use any of them?
As long as the 392 is buildable, I plan on building that one. As for the 354, I’m thinkin I’ll clean it up real well, paint it up and put it on an engine stand to set in my shop for a show piece.
You can also post numbers on this thread. I'm going to call the block as a 341 Desoto "S26" by looking and the other parts. 392's are massive, and I think you only have the 392 heads and intake. The rest of the parts look like Desoto parts. A 354 is a highly sought after engine as well as the 1556157 heads. Good luck.
You can also post numbers on this thread. I'm going to call the block as a 341 Desoto "S26" by looking and the other parts. 392's are massive, and I think you only have the 392 heads. The rest of the parts look like Desoto parts. A 354 is a highly sought after engine as well as the 1556157 heads. Good luck.
Looks like you’re right about the bare block. That said, the crank I have is a 1619647 which is listed as a 354 crank
Cool idea on the display engine…I want to do something similar
Awesome find Dude!!! Congrats!! IIRC, the 392 heads are worse-flowing because the intake ports were dropped to keep the induction under the hoods of the 300 series & Imperials with the taller block. Putting the 354 heads on the 392 is a 1st step output boost, find Hot Heads site, I'm sure the info is there as to intakes etc.
It’s confirmed! The second engine is a 392 Hemi from a 1958 Chrysler Imperial!
Domed pistons
There is a noticeable ring ridge at the top of all the cylinders
And here’s just a picture of the gunked up lifter valley.
I REALLY can’t wait to get my shop built and get some soak tubs set up and get all this stuff cleaned up and freed up! Hopefully be able to do that this winter! But for now, it’ll all go into dry storage.
Bet the pickup was squatting a little on the way home.
Man, I completely didn’t think to take a picture of the truck! You’re right, the pickup AND the rear tires were squatting! The suspension would bottom out on bumps and anything over 50mph started feeling real sketchy! Didn’t help that I had 40’ of 1/2” log chain back there too!
:lol:
You know, I thought of that last night. I can’t remember if it’s got the main caps or not. I’ll have to go out and check
Just bought two 330 Desoto Hemi engines, one without main caps :-( also, I'm wondering if 318 or 340 caps will work with an alignbore. I did get a super rare Desoto tall deck cam made of unobtainium. The other was almost complete.
So, is there a 354 hemi?
Being able to use 318 or 340 caps would certainly be cheaper than buying new ones.
Unfortunately, there is no 354 Hemi, just the crankshaft from one. Now, the main journals and crank journals are the same size between the 341 and the 354 so theoretically, the 354 crank should fit in the 341. BUT. The 341 has a 3.7812” stroke and the 354 has a 3.625” stroke, which would effectively de-stroke the 341 down to a 325.
