Solid Roller camshaft selection those of you running a 408 race application - lobe seperation
On a 408;
2.02 - 105.02 LSA
2.08 - 105.68 LSA
2.15 - 106.41
For a 434;
2.02 - 103.56
2.08 - 104.26
2.15 - 105.03
A 26 cubic inch difference between the two. Notice how close the numbers are the trend of which they go. About a degree and a half tighter going to a larger engine. So is a 105 to tight? I don’t think adding two more wider is going to kill it.
According to D Vizard which is Chevy math for the 23* angle. Being the MoPar has a 18* angle, you could probably do with 2* less and be fine. 1* won’t show crap.
Very true with the four inch crank. I've seen that Vizard states in his seminars a positive correction factor of 0.75 for each point of compression over 10.5:1 and 0.5 of positive correction to LSA for each tenth of rocker ratio increase. So with 12.25:1 as stated by the OP, 1.3 degrees more of LSA. Anywhere from 106 to 108 should be in the sweet spot.
Thank you! Those Duration numbers are the exact ones recommended by Bullet Cams with a 108 center line and 104 LSA. I am still waiting to hear back from Racer Brown. What converter are you running?
Sorry missed the converter part.....was running a 904 and it was 5400ish....just switched to a glide last year and had a couple different numbers on it....first was 5500ish with a 4.56 and went 6.59 but it wasn't as consistent as I would have liked so got it loosened up but my guy went farther with it than I would have liked....it's now 6100ish and went 6.64 with a 5.00 gear. 14x32 tires.
Thanks for that. Good to have it mentioned.
DV is a serious man when it comes to this stuff. It’s still his deep passion. He deals in facts because that’s what engineers do.
Which way do the correction facts work in?
