daredevil
post some useful math like cubic inches equation
Looks like Olds had the most efficient bore/stroke ratio...
Interesting!!!:read2:
But it's the Chevy version which became the corporate engine because it would fit anywhere...
Yes, that, and it was probably the cheapest of the bunch to build.
They are inferior engines in a lot of ways...
Small Block Mopars (SBM)'s have SO many advantages over Small Block Chevys (SBC)'s.
1. Taller block
2. Wider bore spacing (4.44 vs. 4.40)
3. Higher camshaft location (more room for bigger strokers)
4. Larger-diameter lifter bores (better valve action from the same profile)
5. No fonky-*** pushrod in the fuel pump
6. Intake comes off without removing the distributor
7. Stronger rods
8. Longer rods (by a bunch!)
9. Valves centered in bore
10. Eighteen-degree valves STOCK (SBC's had to pay aftermarket extra)
11. Phenolic resin float bowls (T-Quad) for cooler fuel
12. First with electronic ignition (1972)
13. Shaft-mounted rockers 'til '93 (non-Magnum)
14. Impossible to install the SBM's distributor "one tooth off."
15. Everybody and his DOG, doesn't own one...8)
