TrailBeast
AKA Mopars4us on Youtube
Ok so ready to testing but something does not look right. I measured my air gap about 10 times. With it installed, there is a space between the face of the bearing and the fingers of about .145 using a piece of metal as a feeler gauge. While that seems correct it looks cavernous to the eye. Is this correct? Did I do something horribly wrong? I’m on the home stretch of buttoning stuff up so I’d rather pull trans now to re shim before more stuff gets bolted on
It is fully compressed, I have not put fluid to it yet, so maybe it pre loads further out?
Fluid in it or not will make zero difference.
Keep in mind that gap will close up a bit after the flywheel, disc and pressure plate settle in together.
(Usually within a couple of short drives)
Try not to push the pedal all the way to the floor for a bit if you can help it.
