Source for rocker shaft end seals/freeze plugs
340inabbody
Arizona
I spoke to Chrysler and they are not producing the rocker shaft pressed end seals/freeze plugs. They have not said that they will again.
Spoke with Mancini Racing. They have been out of stock for 8 months to a year.
No one has stock left anywhere
I found a dorman part that might fit. Anyone used these before?
Dorman 555-007
Never seen an "end seal". All I've ever seen were pressed in plugs. Just get the appropriate size freeze plug, put the sealant of your choice on it and hammer it home.
I tapped and used a 1/4” pipe plug on a small block set. Just check the depth to the first bolt close to the end. And yes you can use some sealer for the threads. Swingn’
