Dental Dart finally showed up.....Help Tonya and I disassembled this block..Looks like it is going to machine shop....had not planned on it...but had a bolt break off while removing timing chain cover...I am not going to drill and tap this one...plus we will it hot tanked....everything looks good for an engine that has been sitting fo 30 yrs...bearing look good....since the block is going in...I am going to get the crank polished...So this kind of delays work on this engine for a few weeks....
WE are going to work on assembling the 360 that I put the crank in a couple of days ago...gotta file the rings......and then start knocking the pistons in....
