Well...have another block that should be coming out of the machine any day now....the 360 that spun the rod bearing....being bored from .030 to .040 and decked to 9,58,,,,,as i said...I have a complete .040 rotating assembly with stock internally balanced crank...scat i beam rods...and SRP flat top pistons....I check the parts bins and I got the main and rod bearings..plus .045 rings...should be good to go once the block get here.
Going to use Eddy ported heads that SDSS did many years ago...and were freshen up went a couple of valves got bent from a broken timing chain...thank cloyes...
Intake holley SD or maybe a Mopar M1....just got it...
So the big decision is going to be camshaft....Which solid lifter cam to go with...
1. Hughes 6064....260/264 .615/.621 108 LSA
2. MP 590 271/271 .590/.590 106 LSA
3. Howards
Howards Cams 712532-06 Howards Cams Mechanical Flat Tappet Camshafts | Summit Racing 260/264 .562/.562 106 LSA
Have had good luck with 1 and 2......
Might add at 1.6 rocker on the Howards cam and MP590 cam
All three are here....Howards cam showed up today...nearly a month after ordering it from Summit.....
