Hope to see you down at Carlisle Jim.
Dave
Dave
As always nice work Jim.
I love DMTI made e-mail contact with Jim Fillmore at DMT about the foam seal across the top of the windshield and hooked him up with Carl who posted the original photos of this seal. Jim wanted the seal so they could reproduce it and make it available to everyone and Carl is going to send it to him.
DMT has the correct seal material, so I asked him to let me know the cost and to send to me.
Just got an e-mail to say it is sent and no chargeOO
That is excellence in Customer service.
I had always recommended DMT for seal - and now they are highly recommended!!!
Jim
Thank you Jim. The body shop tape on my beautifyul mylar lower trim and pulled off the chrome. That's why I went with the original chrome lower strip. your restoration on everything convert. will help me big time. Thank you.I'm doing the mod that others have done to eliminate the "chrome" lockstrip along the lower edge of the windshield.
I'm using a hardtop windshield gasket and using a lower S/S trim strip from the hardtop/fastback cars. This involves cutting off ~1" from each end of the hardtop trim strip and doing a little grinding on the ends.
Then you install the trim clips that are used on the hardtop along the lower edge. All the screw holes were punched along the bottom - except for the 2 outer ones. On my car, they didn't seem to be there, but maybe they were covered by the body shop. (These 2 outer trim clips are a little narrower than the others.) The 2 outer clips are p/n 6002615 and the rest are 6002263.
Mocked up the throttle linkage today using the stock accelerator pedal and the Lokar cable to the FAST TB. Now I see that the throttle only opens part way with pedal to the floor!!! can't have that!!
If I move the cable connection to a pivot on the TB (photo 3/4), I can get full open on the butterfly. This means I have to make a new bracket for the cable end at the TB. Mumble, mumble ops:
Thanks Jeff WAs a lot of fun but with challenges along the way - which makes it even more enjoyable.Wow.....I'm late to this party but what a BEAUTIFUL job you did on this car!!!!!
Jeff
Stay safe
Jim
This is awesome info, thanks guys!!Yes - RMS Street Lynx rear. Other mods are a Moser 8-3/4" rear axle. I looked at used Mopar 8-3/4" axles and by the time I fixed them up with new gears, bearings, sure grip and axles etc- I though it was far better to buy brand new parts.
Due to the use of rear disk brakes, you are usually limited to using the "Green" ball bearings in the axles to control end play. From an engineer's perspective, I don't like them at all because they have limited capability to take side thrust - unlike the original Mopar tapered roller bearings - that are virtually indestructable. Bill at RMS said he has used Ford (did I say Ford??!!) tapered roller bearings with the Moser axles and disk brakes - so I am going with those.
By the way - Bill is a great guy to deal with. A real treat. I drove down to his shop to pick up my suspension and Bill was very helpful. He spec'd and ordered all the Moser parts for me.
That is pretty well all the major mods I have in mind. I'm keeping the interior absolutely stock.
wow!!OK OK here is the first peek!!!! The AC compressor is the one in the foreground on the pass side.
haha!Have started to get ready for the first trial fit of the motor and tranny into the car.
I needed a support stand to sit the engine and tranny on so we can drop the car onto it and bolt the RMS suspension frame to the frame rails.
Being an engineer - I had to do many design calculations and drawings - so after 3 weeks of intense work at 12 hrs/day , this is what the result was.
