chrgdrt
Not the greatest pic but here the rockers I have, bushing material looks to be steel of some sort. Shaft has oil holes but not the grooves.
Are those comp cams rockers and shaftsNot the greatest pic but here the rockers I have, bushing material looks to be steel of some sort. Shaft has oil holes but not the grooves.
I’m pretty sure they’re speedmasters. I picked them up about 5 or 6 years ago, haven’t used them yetAre those comp cams rockers and shafts
Yeah, they'd gaul on the shafts if they didn't get enough oil. I think that's why they went to the bushings..Did they have problems?
What Hemi came with hydraulic lifters?Did the hemi have grooves? I don't think so.
Then they probably had nanner grooves.1970-71.
Here’s a better pic, they do have two bushings but not bronze.PC. That is a ProComp/Speedmaster part #.
Pretty sure the Comps have bronze bushes, one each side.
Some Prw 1.5 rockers i got a while back. from Mancini. maybe a year ago.
seems the PRW have bronze bushings and the speedmaster use steel? same rocker casting. some other hardware is probably different...
Do yours have one solid bushing, or two with a spacer in the middle like in the photo above?
mine have two bushings with a small bevel on each end. They are pressed into the body touching.
Did Mancini send them with cup adjusters? What oiling pushrods you planning on using?
(Apologies to the OP for sidetracking).....yes those are the adjusters they came with, they actually left the locknuts out of the box and I contacted PRW to get some sent to me.
not sure on pushrods, I'm building an LA motor, SFT cam with EDM lifters. Not sure if I will use pushrod oiling...
Are your adjusters fully threaded with no oil band or hole on the side, like these:
Are those rockers drilled so oil is delivered to the threaded bores?
