I missed it too. Was eating brekkie. No worries.
Here?Boy howdy! Could that be taken out of context? Or what? Good morning.
yer kiddin. right? tell us you're kidding.Hey how about the thread where the guy wonders if you can bore a block out until the bores are gone then sleeve it. ya that'll work good!
Not sureThought. Is the water valve to the heater core vacuum controlled?
both the nearly the same temp according to the infrared thermometer, 178 degrees and 174 degrees on the outletHeater hoses close to same temp with fan on high? I bet one is noticeably cooler.
I check them with an infrared laser thermometer. In my experience, if it’s blocked, one will be drastically cooler than the otherHow do you check heater core for blockage?
I have always taken the hoses off and blew air through them.
That’s what I used to do before the laser thermometer trickI have always taken the hoses off and blew air through them.
Pull hoses off engine, one end in a washer fluid jug,funnel stuffed in other hose. Cuppa water then air. I use a rag around blow gun for back spray.I have always taken the hoses off and blew air through them.
They get ugly for sure. Always hated doing them half the time you have to make the core fit right.Pull hoses off engine, one end in a washer fluid jug,funnel stuffed in other hose. Cuppa water then air. I use a rag around blow gun for back spray.
Most effective method so far.
I built a gun that i put water in. Then pull a trigger for air. Reverse directions also.
Jug is to trap what comes out To see what was in core. Its suprising what that core catches.
Yeah I was shown it by an engineer for Cummins years back, so far it’s been fairly accurate. I think I will go ahead and flush everything thoughNever tried thermometer. One hand on each heater hose.
That is true. Thankfully I missed that generation by 3 yearsRemember the millennials have no feeling in the hands and unless there is a procedure on the net it is wrong!
I’m awaiting for it to warm up, then gonna go out to my property and let the kids free runSo true though drives me nuts threw a few out of here for that crap! Woo hoo the beer store is open later guys and Gals?
Something that Ben didn't hit...LOL can see this now all the posts trying to hit it!
Deep subjectWell well well....
Nope, needs a cigar
You guys know all the pics didn't help. It's 25 posts per page regardlessTrying to turn the pages to 10000 Just a couple more.
Not. I fugured it was going to be the y2k thing and reset itself to zero or something.And I'm Back....Looks like I missed all the fun this morning....Or Not ????
And I'm Back...
Are you just a Front Man ??I'm front...
They had a couple of pictures of you, or someone resembling you.And I'm Back....Looks like I missed all the fun this morning....Or Not ????
Oh Yeahhh ???They had a couple of pictures of you, or someone resembling you.
Think that counts
