Stop in for a cup of coffee
Did you hear that a psychic dwarf escaped from prison???
Police are now looking for a small medium at large.... :BangHead: :D
I am just up moving from the living room to the bedroom...
Thought that I'd check in and see what's going on...
My cold is starting to flare up again... :wtf:
The oldest kid now has it.... :(
It's going around work also... :mob:
We went to bed early after doing the bathroom remodel last night. Had to insert ceiling exhaust fan. Up ladder crawl in attic over and over. Everyone was whipped. Woke up early and ready to go. Going to a Bantam hockey tournament today. Should be a hoot but will lose valuable time thrashing on the Demon. Paint day is 2/25 and I am a long way off yet.
My youngest son came back from Detroit yesterday... It's supposed to get in the high 40's and dry so we may be able to work on the wiring in his 65 Barracuda today...
Ok, back to bed...
Hopefully I can wake up early to watch my home flipping shows on A & E....
Good Morning....an echo in here well guess no one is here.
Well good for you. What you want to get done today??
Probably do some touch up work and fitting on my tail panel swap and my quarter swap. I’d like to try and get my quarter windows out so I can spray that area before I weld up the new panel
I helped my restoration buddy put windows back in a 34 Ford a couple weeks ago what a PITA!!
Not much here have to see who I Can borrow a large slide hammer and a adapter to from to pull the cuda axels out. They are in there.
There is like a spring ring into the carrier on the shaft splines no other way to do it. have to be pulled. I now see why these rears grenade. Really light duty for sure.
This one is a bit different from the 66 one I pulled from the Belvedere. I would be iffy running a worked slant on it.
