Stop in for a cup of coffee
Took a few sets to make one good one. All the bolt brackets were rotted out especially the right side prob from the peg legs.
Here is the same optioned car. Prob better off I did not get it it had a 389? Tripower and I was 17
You are probably right, I had a friend with a Pontiac Tempest, tri power. He didn't know how to work on the progressive links to the carbs, then he didn't know how to get around a corner WFO, ended up taking out a row of mailboxes. Traded the car for a couple of old El Caminos after that!
Letting it warm up a few more degrees then run over to the junkyard. Still need to find a wheel that matches the original 3 on the neon. The other yard that thought he had one, wanted to sell me the same style I am trying to replace for $25. :BangHead:
I go to Tempest search and type in NOS 67 Barracuda.
Hit show all. I go through each pop up and see what they have.
The last window is NOS. Its ebay mostly, but a lot to go through.
Yep. The back ones are the worst. I think they get a little dirt and salt in the bottom and no way out. Over time everything in there disintegrates.
I took the chrome center caps off the wheel covers. They were heavily rusted on the inside. 10 minutes on the bead blaster and they were looking new again.
When I took the dash out I had some rust on the inside of it. I went to O'Riley's and got a spray can of a recommended rust prohibitor. Sprayed it on and left it overnight. Area turned a dark blue both. It both treats the rust already there and helps prevent future rusting. Can't remember the name came in a blue can.
I have been using the Rustoleum stuff. Just looks like black primer. but that's only good for thin/surface rust. We are talking chunky scale in these things. lol
Oh ok ya need to clean that out for sure.
found a few referenced online that say vinegar will wreck chrome. Evaporust sounds ok. may be a couple others better/cheaper though. Will be looking into options.
Dinner last night... Yes that is a complete Fish...
No baby mice,, thank God,,,,
So looks like my el cheapo wire feed welder has finally bit the dust. I have been nursing it along for about a year. It smoked this morning! Now I got to replace it. At least I can spend the money with a good conscience. I have wanted to replace it for last couple of years but was just to cheap. Figured I could just keep fighting my old one. A little aggravating was cheaper than a new one. Not in budget, arghh.
Miller, Lincoln, Century, Hobart Spend extra but it will last a lifetime.
Tell you what @PosiRon bought a cheap gas mig from HF works great!
