I have to itemize a crapload of stuff around here and add it to the homeowners. Just a PIA a pic of each item and a declared value.
Sounds like great coverage.What I always do on the drivers is 100/100K, and comprehensive and for a extra $2 towing and trip interruption. Hell they paid out for the tow and part of the tire on the blowout I had last month In five days. I use Donegal on all the drivers and the house. Hell the tractor is covered under the house for theft with all the implements.
Yes. Shifter in car is dual type,From the cable shifter?
You can probably get one made up at a farm equipment supplier. The make push/pull cables usually.Yes. Shifter in car is dual type,
And i am putting in a later style 904.
If i want to stick with cable shift i need to put a lighter spring in the vb detent. Then i need to find a proper cable.
Suppose I should ask again when renewal comes up.Only a few bucks more and I am pretty much covered. I learned a long time ago if you cheap out you feel like you got ripped off.
Comprehensive is a must around here with all the deer running around.
Type it out in a letter and cc at the bottom to a lawyer (esq) if you know any. Even if not, a written letter doesn't (unless you write something stupid which I'm sure you wont).
Joe who fixed and painted my Barracuda did a lot of bread and butter colision work, and also some select salvage title repairs. He told me all repair panels need some tweaking, the factory ones less, the aftermarket more. So its labor costs vs parts cost. Since they should cover the parts costs, I'd go for an original and save on the time if you can.
Pto cables. My guy can get me whatever i want. Wasnt thinking when i had trans apart to find a lighter spring.You can probably get one made up at a farm equipment supplier. The make push/pull cables usually.
Makes sense. BTW the missing words were to the effect of a written letter never hurts and helps make a record.Let's say it's a sub standard insurance company... They only pay $28 per hour for labor when standard rate is $52...
My brother is an insurance adjuster also... He's been helping me find the parts in the same color so we can save money not having to have the repair panels painted since they do not pay much for labor... This way we can get the car finished within the budget that they are giving me...
But we can buy an aftermarket fender and paint if for what I can buy one out of a salvage yard... Since now the ones are either in Urbana ( 1 1/2 hours away) or Ohio (about 4 hours away)....
I did! A box of ammo a fishing vest and lunch
Inners from a 75 duster work?Morning gents. Going to shovel some wet snow and might try and pull fenders off today to reveal inner fenders.
good to know. I could use a tractor.
I could use some implements....
Oh wait, I mean implants....
I went with a pair from AMD as I have zero body work skills, of course Fargo has been cut off from the world since Wednesday as a result of winter storm. They just reopened the roads in and out of town. So no parts yet. Thank you very much tho.Inners from a 75 duster work?
I want a pump like Wolfie
