straightlinespeed
Sometimes I pretend to be normal
That is a very good question.. Does it help sure, is it needed, nope.There are questions we don't have answers for.
Does the bacon bikini need a woman in it or not?
Could we see them separately first?There are questions we don't have answers for.
Got'er done though. You can pat yourself on the back all weekendGood morning, I feel like a ladder was dropped on my back this morning, removing the spring from the clutch about whooped my ***, so glad this is dun
I will raise a beer to it some time today, then back at it, it's getting harder and harder to reach fare enough to pat myself on the back Good morningGot'er done though. You can pat yourself on the back all weekend
I bet! Springs are rarely easy, or fun. Best I can say is they are a challenge. Parking brake cables are another royal PIA.Good morning, I feel like a ladder was dropped on my back this morning, removing the spring from the clutch about whooped my ***, so glad this is dun
But... when the doctor says "You need to eat better". Give up the bacon or the egg?MMM bacon and egg on a Kaiser roll! Good stuff rhere
the 65 Cuda I am still parting out.Thank you @halifaxhops for the great deal on the big foot peddle , what car did it come off of my friend ?
I need to look at mine. Oil pressure and temp have been off for the past 10 years or so. Keep putting off figuring I'll do it when I get the face vacuum plated and that plan isn't working out.It is. He's a smart MOPAR guy he'll figure it out, I'll give him a case of beer and it will be all good.
I had to use the grinder to cut one of the hooks that hold the spring towards the dash, then I used a heavy string and got out from under the dash and pulled very hard, I was so happy to see the spring hit the floor boardLast time I got under the dash on the Demon for pedal work I got in a death match with my grinder which is paddle operated. And yes of course I disable that bothersome little safety switch just as soon as I get it home, I put it with the miserable little guard that goes around the wheel! Hah! Did I mention I had already caught my shirt on fire at that point?
Morning gents and one Lady.
Try to make a fun journey of it if you have time.Good morning coffee crew. I am on Holiday starting today for a week..ish. Heading back to FL. Driving this time though, yuck. My son is playing in the band at Disney, have to go see that. I hope all is well in Coffeeland.
I can see that the Automatic foot peddle was easy to take out, the big as clutch spring was a ***** to say the leastThat set was easy to get out no instrument panel, vent box and the floor is so gone I was n the grass doing it!
Congrat's !! that is a super thing to be a part of, good luck to his time there and safe travels to youGood morning coffee crew. I am on Holiday starting today for a week..ish. Heading back to FL. Driving this time though, yuck. My son is playing in the band at Disney, have to go see that. I hope all is well in Coffeeland.
That's not correct. All the lamps operate on 12 volts. Even a oil warning lamp is on 12 volts. Voltage limiter or regulator is only for thermal gauges, fuel, temp, and oil.Yup and the instrument light bulbs go on it also.
Nope fuel gauge hasn't worked right since I got the car. They had an aftermarket under the dash oil/temp gauge. I took it out put the new senders in with a new harness. I used one of Ray's testers when I had the dash out and the gauge needles did turn. I'll send you a PM later today. Thanks!!More... You only pointed out issue at 2 of the 3 thermal gauges. If the OEM fuel gauge works, any of the 3 works, the regulator is working, since the one regulator supplies 5 volts to all 3.
I tryed that, it would never open up enough buy pushing or pulling the clutch , I had 8 nickels in that thing , I figured everyone new this as wellI thought you opened up the spring and stuff coins or washers in the gaps then let up on it and the spring just pops right off?
Well crap!!I tryed that, it would never open up enough buy pushing or pulling the clutch ,
Ask @66340SEDAN . Keith will know the answer to that one.There are questions we don't have answers for.
The heavy string worked, I stood outside the car and gave it a big pull and it feel ourWell crap!!
